Are there any codes showing for the ABS issue? Could be anything from an errant wheel sensor to the ECM for that system failed---also hoping it's something cheap and easy to fix.
What's the specs on that awning---I've been kinda sorta look for something that size for the side doors of my raised roof 2005 E350.
I ran the codes, i can't remember what resulted but basically there was no signal and i couldn't reset the codes. I'll check them again to see if i can get further details.
As for the awning i bought it used and it came from one of those big RV and was used to cover the entry door. It's made by Dometic. I can get the model# if needed.
One lonely little picture today of the smaller courtesy light installed so I don't blind myself with the larger side lights...
2008 E350 Hambo
2001 E350 AmbuLand (sold)
1970 Econoline popup camper
1965 Econoline Travelwagon
If you wouldn't mind sharing the model number I'd greatly appreciate that.
Did you solve your electrical issue? I have wiring diagrams for your rig but they are broken down in certain categories.
Let me know which ones you need and I can upload them for you.
If you could share the ABS, computer data lines (and maybe the starting/charging one) that would be immensely appreciated! It started to rain pretty solid here so would be nice to have 4 wheels going instead of my 2 wheelers, love riding my bikes but there are days where a roof would be nice
Cheers
David
2008 E350 Hambo
