yep, been there with the TRAX but in my case the display and control worked but the transfer pump inside the aux tank had failed. This was years ago and TF did a fix that cost $1100++ back when $1100 was a bunch of $$.
In my simpleminded hindsight I probably should have just found an external two way pump and figured out a way to plumb that in. There are crap load of hoses if I remember correctly.
The rear tank is only transferred (filled or drained) via a pump, there is no separate external rear tank fill. If I was going to get fancy I would have added a second fuel gauge to measure the rear tank.
The TRAX setup was always monitoring the two tanks and transferring fuel to keep the two tanks about even. Seems overly complicated.
