01-01-2018, 07:10 PM
#61
Originally Posted by arctictraveller
I did re-read the entire thread. I'm no diesel expert though and I still wonder how you make that much boost. Does a bigger turbo make that happen? Turbos often times have some form of boost limiter to limit boost, if you don't have one, will boost pressures simple continue to climb sky high? Detroits have both turbos and superchargers to get more boost, would a bigger turbo do the same thing? Thanks........
Oh. No problem. So, factory turbo is good for 27-30 psi max. The factory map sensor can only read 35psi. I have larger turbo , Borg Warner S369. That turbo is good for 55+ psi depending on applications. You also need the fuel to get that turbo lit. I have 225/100 injectors. So fuel + bigger turbo = more boost
01-07-2018, 10:55 PM
#62
So bada**! Have you gone on a long drive yet? How are your temps?
Hi, I’m Robert and I’m a vanaholic…
2003 Astro AWD
1999 E350 RB 7.3 cargo
2002 E150 RB 4.6 hightop van conversion
1999 E350 RB 5.4 Chateau
01-09-2018, 02:36 PM
#63
Sure have... at 90-95mph my EGT is around 850-900 degrees ... EOT / ECT is 190's and when I step in HARD and stay in it will touch 1600 on EGT. All that is completely fine.
01-10-2018, 09:46 AM
#64
Originally Posted by BullGator
...at 90-95mph...
Dayum! That's already a win. That you can keep your temps down doing it = PARTY!
2003 Astro AWD
01-10-2018, 11:30 AM
#65
That's pretty amazing. My cruising EGTs at 70mph on flat ground are 800-900F. Max I'll push it too is 1400F. That's with the pyro mounted pre-turbo. I'm at ~400HP with my mods.
2011 VW TDI Golf for hwy fun
01-11-2018, 08:43 AM
#66
Amazing numbers and work!! I may have missed it but, what are your plans with the van? Camper, moto, shop van?
2000 E350 Cargo PSD w/ UJOR 6" Lift
01-11-2018, 07:04 PM
#67
Kidnapping children? rapid response plumbing? Mall cop? House painting in one hour?
01-23-2018, 09:18 AM
#68
So far I am just running the toll roads and gapping anyone and everyone that wants a piece lol. I have a new Z06 under my belt, put a school bus on his from a 50 roll
I have a diesel shop in Texas... it will be more or less mobile advertising.
06-11-2018, 08:22 PM
#69
Either way good luck keeping it together! Keep us informed! Aluminun tolerance is 1200* if the temp is influxed it can take it but add a load and ? However if the temp in the cylinders work in conjunction with the pressure of that temp would it not take longer for the melt to start? Like a coolant in a radiator under pressure the boiling point is higher! I dkw just thinking out loud!
06-12-2018, 11:18 AM
#70
Over 700hp to the wheel and ticking. Beating the shit out of it on a daily and she keeps asking for more.
