04-19-2024, 11:26 AM
Colorado Camper Van Replacement Mattress
As a proud owner of an E350 van with a Colordado Camper Van poptop, I have my bed up top in the popup area. Unfortunately, the Colorado Camper Van mattresses leave a lot to be desired.
Step 1, I pulled the open cell foam out replaced it with high density memory foam. This made no real difference.
Step 2, I put 1/2" high density foam between the mattress pads and the support. This made no real difference.
Step 3, I put two Therm-a-rest mattresses, 2" thick, between the mattress pads and the support. This made it tolerable, but we now had 5 pieces moving around - main mattress pad, the two extra pads, and the two therm-a-rests.
Step 4, big brain time. Took all that garbage out. Replaced it with an Exped Megamat Duo 10. Fits perfect, nice and thick, one piece, folds up if I want more head room. Underappreciated advantage - since it has air chambers, it will collapse more than the stock mattresses. This lets me leave a thin bed made up and still not run into issues putting the roof down on my low top CCV.
The stock CCV stuff I bagged up in one of those mattress vacuum bags, when I move the van on down the road I will toss it in the back, along with all the other stock stuff I have removed.
04-19-2024, 02:14 PM
I am using the same but I have the OG SMB mattress. I believe they increased the thickness of those at some point. Mine is a 2012.
2012 E350 SMB/Quad Van
2021 Chevy Colorado ZR2 Bison
04-19-2024, 06:43 PM
We had the same issues with the stock CCV mattress pads. I added a slat/spring bed base from IKEA. You can see pictures in my build thread.
https://www.sportsmobileforum.com/fo...tml#post261346
Since this post I replaced the 4" foam with a 6" foam mattress, since we have a high-top CCV, I had plenty of room for the springs and a thick mattress. This setup has been great for comfort.
04-21-2024, 09:21 PM
My 93 SMB has painfully thin mattresses in the penthouse. It is also divided into 3 segments. If I could get up off my butt and measure the bed which I think is a full, I could go with a 6" memory foam trifold mattress, take the cover to my local tailor shop and make the individual segments separate from each other and sewn up.
For the regular lower bunk I have the original pads with a 3" memory foam topper and it sleeps like a dream.
04-25-2024, 10:21 AM
We bought a 3" medium (30 ILD) latex mattress for our pop top mattress in 2018. Recently we were looking for more comfort, as my wife is a side-sleeper and the 3" mattress wasn't enough for that. We ordered a Froli STAR kit this spring, and it has been a huge improvement! It adds 1.75" of height, and the springs are individually "tunable" so you can have softer or firmer zones. Not cheap, but highly recommended.
https://nickleatlantic.com/collectio...iant=706482855
04-25-2024, 11:13 AM
Thanks Big Ern, between you and Steve_382 (trying to sell his van for a while), I learned about Exped...got the wife bought in, now just trying to figure out which one to get. I've got a separate thread going on this subject, so I will report back there about what we get.
I love this forum!
MarinBlaine
"MooseMobile"
2001 E250 5.4 EB50 Aero Hightop
04-25-2024, 06:33 PM
We got a quality air mattress. Deflates flat for dropping the top with blankets, but it's soft for sleeping.
04-28-2024, 11:19 AM
If you have the low roof CCV, Exped Megamat Duo 10 fits with no issues at all and leaves enough room to collase the roof with sleeping bags or blankets - still gotta pull the pillows down. I don't think the thicker one would work.
If you have a high roof CCV, the thicker one would fit but I don't like the idea of that large of a gap between the mattress and the side wall. And with the smooth support under the mattress I dont think I would need a thicker mattress. Not like you are trying to absorb rocks and roots.
If you have a Sportsmobile - I can't help ya.
I am now at 10 days on the Exped mat since I bought it and loving every second of it. Would pay double.
04-29-2024, 12:21 PM
So are you putting this directly on the boards and removing all the foam cushions that come from CCV?
04-29-2024, 07:35 PM
Correct. All the foam and fabric has been stored in one of those mattress vacuum bags you get on amazon for $20. Will be perfect for the next owner.
I put my new mattress directly on the rigid floor of the CCV top.
