Old 04-06-2024, 09:18 AM   #11
I have NO idea why pictures always get reoriented on this damn forum...
PDXDave is offline   Reply With Quote
Old 04-06-2024, 09:53 AM   #12
Originally Posted by PDXDave View Post
Since I originally posted this, I removed the antenna mounts and fabricated a proper set that do not require the wedge shaped shim. At the same time I moved them down the fender to get farther from the van body. I also upped the nut-sert size from 10/32 to 1/4"
The whole thing works better now and is much more solid.
So my current CB antenna mount is a pre formed stainless steel gizmo that looks a lot like what you have set up, just no NMO mount bur rather the standard 3/8-24 mount CB antennas (and 10 meter etc... ) use...
I can dimple the metal and poke holes for the nutserts, but cutting and shaping it not so good. I don't suppose you'd be interested in fabbing up another one of your passenger side mounts to sell at a reasonable rate would you?
The nut-serts and associated tool came off the Snap-On truck probably 25 years ago, but you can get nut-serts on Amazon as well as a very good Marson tool for installing them, if you don't have one.
I answered my own question. Not a tool I will use a lot, but as I move forward with the rebuild. I want to redo the interior properly, I.E. remove the sheet metal screws in favor of machine screws for the interior cabinets etc... So I got one on the way.
https://amzn.to/3PRgx97
Also picking up a large assortment to get my started of both SAE and Metric rivnuts in stainless steel. I suspect 10-24 and 1/4-20 are going to be my 2 most common size choices though. Those SAE sizes from that assortment sure don't look like stainless steel to me though...
https://amzn.to/3J70Ir9
dbhosttexas is offline   Reply With Quote
Old 04-06-2024, 02:19 PM   #13
marret's Avatar
Not only this forum.
If you hold the phone horizontally with the lens on the left when you take a photo or slightly crop the photo before posting, the photos should post correctly.
Chris
Old 04-07-2024, 10:26 AM   #14
I might add that the bracket that’s held down by a fender bolt has never moved even though there is just one bolt holding it. A 102 inch whip might be a different story though.
Old 04-07-2024, 10:33 AM   #15
One major reason for the rivnuts. Secure the Y axis... that 102 is a beast.
Old 04-07-2024, 10:44 AM   #16
1der's Avatar
I also recommend having Plus Nuts in the arsenal of fastener solutions. I like them better than rivnuts in many cases especially on thinner metal due to a bit more latitude in the drilled hole and the four fingers grabbing on the back. Depending on the tool being used, many times only a slightly longer mandrel is required.
Old 04-07-2024, 01:02 PM   #17
Attachment 50273
I've seen fasteners like that for drywall, this is the first I have seen them for sheet metal. Pretty cool. Yes it will give you a much larger "bite" behind whatever you are fastening to...
Old 04-07-2024, 03:42 PM   #18
Good thing I don't need that rivnut tool today. Amazon says it was shipped, scheduled for delivery by 9:00 P.M. It is already 4:40 P.M. and not yet on vehicle for delivery... Sure it is gonna be here by 9...
Old 04-07-2024, 04:09 PM   #19
1der's Avatar
Yep AMZN delivery projections when purchasing have become absolute BS. Delivery pushes out days (multiple delays) from what they 'promise', it has become the norm.
Old 04-07-2024, 06:14 PM   #20
Well, it is funny, they usually won't say delivery by blah unless it is in the local warehouse. I don't get ANY activity info on this. I think their system glitched.
