Old 07-07-2011, 10:45 AM   #1
dhally's Avatar
Hoop step interference with aux battery
I'm planning to put the aux batteries on the frame rail on the passenger side. This is the same location many diesel owners have a battery. I'm also planning a Carr superhooop in that location.
Does anybody know if there will be an interference between the battery box and the hoop step mounting bracket? The battery I'm looking at is a Group 31 mounted on its side, which will protrude from the frame rail about 10" including the battery box. This is about 1.5" more than the stock battery box.
2009 E250 RB 5.4L "SilVan"
Old 07-07-2011, 11:07 PM   #2
Re: Hoop step interference with aux battery
I don't think it will work. I only have 12" between the frame and body and my Carr hoop step mounting bracket takes up 3" of it, the dimension you have the question makes in.
Old 07-08-2011, 08:02 AM   #3
scatter's Avatar
dhally, your dimension in question on my Carrs is 3-1/4"
Scatter
2007 RB50, 6.0
K1WGB
Old 07-08-2011, 09:30 AM   #4
dhally's Avatar
Thanks for the info, scatter and jwintersteller. Back to the drawing board. I may end up with Group 65 batteries.
Old 07-10-2011, 01:35 PM   #5
dhally's Avatar
I emailed Carr and they confirmed that the dimension is 3".
Old 07-10-2011, 05:31 PM   #6
scatter's Avatar
I just checked mine again. Bracket itself is 3-1/16" (sorry Carr). Depending on what angle you rotate the step to make it level, it will stick out past the bracket. Mine takes up 3-1/4" of space. There is plenty of material on the back of the aluminum part itself to where I would think you could grind some off to keep it to the width of the bracket. You could also grind a little off the back of the bracket.
So, I could have fit mine into a 3" space with a little effort.
Go for it.
Scatter
2007 RB50, 6.0
K1WGB
Old 07-10-2011, 09:22 PM   #7
dhally's Avatar
Thanks for checking it again. In either case I need to revise my battery plan, or give up on the Carr hoop step. I would probably just rip it off on a stump anyhow.
