Originally Posted by SheepShagger
If you mean placing that where the stock license plate is, the issue you'll have is running water / hose in the door jam. I don't see the a hose lasting long with the opening and shutting of the door.
This was my first concern and assumed I could either do a quick release like larrie mentions or some other sort of "connect it when I need it".
Originally Posted by 86Scotty
Audisnapr, you do mean this on the INSIDE of the door due to your box being on the outside? Just curious.
No, I meant for the shower to be on the exterior of the rear door where the license plate tub currently is. My earlier comment about the box was poorly worded - sorry.
Originally Posted by jwintersteller
The other thing you have to consider is your lines and the shower valves freezing.
Very good point. Hadn't thought of that.
I think one of the bigger challenges is mounting the shower tub cleanly into the existing license plate tub - the biggest problem being the door handle that's integrated into the tub - the handle obviously has to stay.
BTW, I may not need this type of shower assembly since I don't have hot water in the van. The only reason I selected it was because of it's proportions, which coincidently is nearly the perfect size to fit in the license plate tub and still keep/use the door handle.
Thanks for the feedback/suggestions!
