Old 10-04-2009, 04:14 PM   #341
scatter's Avatar
Re: What did you do to your SMB today?
Changed both fuel filters (ya gotta love getting to the secondary one) and the external transmission filter. Trans filter had lots of super fine black stuff in it same as last time. Sure is nice having one on the outside so easy to get to. Anyone that has one really should change it. Cheap and easy
Scatter
2007 RB50, 6.0
K1WGB
Old 10-05-2009, 12:14 AM   #342
Aldercrest's Avatar
Added SuperTrack spacers on the rear axle and rotated the wheels (5-tire rotation). Took Vanna out for a quick trip around town and am very happy with the handling improvement from the spacers.
When I remounted the spare (Aluminess rear bumper with spare tire mount), I found that when the tire contacted the tubing, I was still 3/8" away from metal-to-metal contact on the mounting plate. I'm running Goodyear MT/R 305/70/16s. I didn't pay attention to how it was mounted before. I'm not sure I want to tighten down the tire that far, and I assume I need metal-to-metal contact, so I guess I'll contact Aluminess for a spacer. Any thoughts?
2002 E350 EB - Voyager top - 7.3 - Quigley 4WD
Aldercrest is offline   Reply With Quote
Old 10-05-2009, 08:00 AM   #343
scatter's Avatar
Yeah, you really want the wheel to be metal to metal with the mounting plate. Must be a different offset to your wheel then mine. I have 315's and no problem. A spacer would be easiest and pretty easy to make. Be sure you don't need longer studs....
Scatter
2007 RB50, 6.0
K1WGB
Old 10-05-2009, 01:55 PM   #344
More important that the metal to metal is the fact that your tire is touching the outside bar in two places, something I came across when making the spacer for mine... get your final opinion from Aluminess though.
Old 10-05-2009, 02:48 PM   #345
3/8" isn't too bad. I'd think 1/4" would be ideal, but I'd settle for 3/8". You want the tire to contact the metal tubing. It helps support the weight, stops any wiggle or movement of the tire/wheel and prevents bending motions on the solid mount.
The smooth tube won't wear the tire sidewall.
Don't worry about.
Old 10-06-2009, 10:02 AM   #346
scatter's Avatar
I agree that it's super important for the tire to hit the tubes in a couple of places to keep the whole thing from flexing. In my opinion it's also necessary to have full metal to metal contact with the rim to mounting plate. It's easy to get with the correct spacer and keeps everything super solid. I wouldn't do it any other way, but then I do a lot of dirt and washboard. A 315 tire and rim with any wiggle is a problem down the road.
Scatter
2007 RB50, 6.0
K1WGB
Old 10-06-2009, 01:18 PM   #347
Aldercrest's Avatar
Thanks all. I contacted Aluminess and Dave is sending a spacer. It's only going to cost $412, but it comes with a free ladder. Shipping is extra.
Old 10-07-2009, 04:35 PM   #348
You took advantage of the Aluminess forum special didn't you?
[EDIT] Apparently many of you don't scroll down and just post everything in Gen/Tech...
viewforum.php?f=25
[/EDIT]
Old 10-08-2009, 06:26 AM   #349
Today I just placed an order for a wind shield cover from:
http://www.goldrv.co.uk/parts/5/covers/ ... ld-covers/
I know you guys on the American Continent get your stuff "locally"... but maybe some SMB fans in the EU might be interested in Gold RV...
+ 2001 Saab 9-5 Aero Hirsch
+ fixed house (Argh)
Old 10-13-2009, 08:35 PM   #350
Installed a Smittybilt I-rack. Took 15 Minutes... Will have to make one modification in the near future to accommodate the mounting plate bolt pattern.
Before:
After:
COJC is offline   Reply With Quote
Wanderjahr
wanderers
quigley
4x4Ken
