I finally got around to finishing this project. I went with two 5' custom hoses. It comes in 6' increments and I ordered two 6' and it came as a 12' hose. The fitting are easy to install on the ends. You can get strait, 45 or 90 degree. I ordered some extra ends not knowing how the hoses will mount and what angles would be ideal. Pictures are shown blow, for those who require custom hoses these work well.
I have two standard hoses from the diesel site I will give anyone interested. Bob I am sure will sell just the filter plus housing and the pressure guage normally sold separately. Given the cost of the hoses you would likely save 50%, if interested in taking on this project. Email me if you want the standard 3' hoses.
http://www.youblisher.com/p/3647-Eaton- ... e-Catalog/ Pages 16 and 17
FBC0800 / FCC0806 - 6 Ft. Length
FCM1139 / FBM1139 - Fits Hose Size -08 (Fitting Size -08)
FCM1145 / FBM1145 - Fits Hose Size -08 (Fitting Size -08)
http://www.aeroquip.cc/fbc0800fcc0806-6ftlength.aspx
I routed the hoses away from the exhaust pipe, incase I go with a larger exhaust system in the future. Also just brought the return rigid hose from the cooler down and the brass fitting rests against the transmission nicely.
Note the routing of the hose over the transmission and secured to to body.
The filter is mounted on the driver's side, in front of both the cooler filter behind the 4D battery and the Amsoil Filter system. I took off the L bracket, drilled a rear hole 1.5" behind the other to set back the unit due to a frame obstruction. The original rear hole became the front hole. In order to allow the pressure guage to fit uner the now overlying L bracket, I had to remount the filter to the L bracket using two 1/2" spacers, one for each screw and a 1.5" replacement screw. That lowered the filter 1/2".
Also note on these filters, when you take the unit off the L bracket there are metal arrows on top indicating direction of flow. There is a bypass valve inside the filter should the filter fail. If the flow is set the opposite direction, the bypass filter will not release under high pressure and no oil returns to the transmission. That would be rather unfortunate. You can see and push on the internal filter valve to test the direction of flow. Flow is from the cooler to the filter and filter 'out' to the transmission 'in'.
All filters are on one side of the van.
