Old 02-24-2014, 08:51 PM   #1
Re: dc-ac inverter/charger
Bernie: You may want to consider using your inverter (at least run a few basic tests) with the remaining single good battery to convince yourself it's not the inverter.
If you have the manual for the inverter, check out the section on setting the dip switches. There are a handful of dip switches that set many parameters for the inverter, like low AC/DC voltage switching, etc.
If you can describe the failure mode in more detail and let us know where the dip switches are presently set that would be very helpful.
Tatonka
gephoto
Vanny Devito
dick
