That is the circuit breaker, the isolator will look more like this:
In any case, it would not be bidirectional. My general recommendation would be to use a Blue Sea 7622 or 7622. When you also install the switch you a get a full range of choices from On, Auto and Off, LED status, and failure blink codes if needed. While not completely "solid state" the relay they use is a latching relay, so there is no power used while it is on or off, only when changing state.
The 7610, 7611 are both FET based, and would get the job done, don't give you some of the same features. Be careful to size the wires correctly, as they usually recommend upsizing due to temperature.
With the BlueSea 7622 installed, you could have pretty much jumped the starter from the house system and been on your way.
