Old 11-11-2022, 09:43 AM   #1
Penthouse tail-light assy
Hi guys -
I am tracking down a replacement for the penthouse tail-light on an 08 Ford, both SMB and FieldVan are out and it sounds like the OEM may be out of business.
https://shop.fieldvan.com/rear-brake...penthouse-top/
Looks like this was originally manufactured by Sierra Industries in Livermore, CA as SAE-U-88--DOT (Brian at SMB West was kind enough to dig out some pictures, attached) but not finding any source for that online.
Anybody replaced these before / found suitable substitutes ?
Thanks,
Martin
F9582F1A-60A9-468E-8E91-DF1872FF5A6C.jpg   763F9187-CDBF-44AE-AFDC-FE7B26B39E27.jpg   9895B735-083D-4604-9DD0-DB51186A7FC7.jpg
mkosina is offline   Reply With Quote
Old 11-11-2022, 12:02 PM   #2
Twoxentrix's Avatar
I believe there were a couple threads on this several years ago - I recall someone just purchased a flush mount LED that was a little larger than the existing hole.
Old 11-11-2022, 05:54 PM   #3
Interested in this too. My third light doesn't work but I'm in the process of removing the penthouse ceiling to fix known electrical issues and I'm hoping it's a wiring problem as the PO cut all of the wires going up there, otherwise I'll be looking for a replacement option also.
MerlinG is offline   Reply With Quote
Old 11-11-2022, 06:21 PM   #4
Found an old thread in some Choachmen RV forum where a shop in Oregon had these specific ones (SAE-U-88-DOT from Sierra) in stock at the time - he doesn't anymore, but has a substitute.that he says fits the same cutout.
I ordered one and should have it next week, will report back on fit.
Old 11-12-2022, 04:03 PM   #5
geoffff's Avatar
I replaced mine with an LED trailer brake light back in 2012. It was a bit of a fiddly process -- I used some putty to angle the light down a bit so it would shine level backwards, rather than angled upwards slightly with the slope of the penthouse side.
https://www.sportsmobileforum.com/fo...html#post74621
This is what original brake light looked like after only 8 years of use. Totally rusted out:
jage did the same thing:
https://www.sportsmobileforum.com/fo...ight-4356.html
2004 Ford, SMB 4x4, RB-50
Old 11-20-2022, 11:40 AM   #6
I installed a "universal backup camera and third brake light" module from AliExpress. It was a couple of years ago so the exact one I purchased is no longer available, but it appears to be this same model:
https://www.aliexpress.us/item/2255800415603872.html
The back is flat and the whole mess mounts over the top of the hole that SMB cut in the roof.
bobthecow is offline   Reply With Quote
Old 02-04-2023, 12:10 AM   #7
Ok, finally installed this, good fit but if I had to do it again the camera combo may be a better upgrade.
0DABBCFB-5485-412B-BDAD-C948260112E1.jpg   2C2AE002-14C9-4DD1-ABC0-D60B438A68B5.jpg
Old 02-04-2023, 12:45 PM   #8
bigriver's Avatar
Looks good Martin. Can you share a link to the light you used?
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
Old 02-07-2023, 01:41 PM   #9
My source was gentleman in Oregon named Kevin who runs some kind of parts store, kvn.wt.7629@gmail.com - I found his contact on another RV forum while googling the original part. Very good to deal with.
I should add the original cutout for the Sierra light is a bit bigger, so the screws on the new light have *just* enough of an edge to go through, so it's important to center it - worked out on mine, together with some sealant for good measure.
Cheers - Martin
Old 03-18-2023, 05:48 PM   #10
Found his card - attached
Tags
penthouse top, tail lights
