Old 12-15-2018, 04:56 AM   #41
I used to do marine installs, sailboats were always a nightmare with the masts and rigging creating shadows. Especially in a marina where you are surrounded by other sailboats plus the one you are working on.
Flipperfla is offline   Reply With Quote
Old 12-15-2018, 08:43 AM   #42
most interesting to read and contemplate.
Quigley-76 is offline   Reply With Quote
Old 07-03-2019, 06:08 AM   #43
OutlawImages's Avatar
Since this question came up in a different thread, I thought I would answer it in its own thread instead of it getting buried in another but interesting thread.
Let’s look at the effects of shading on our solar panels, and ultimately what that means to how we choose our system, position both our panels on the van and other equipment on top of the van. I will try to keep it simple and try not get caught up in the technical issues (Reverse bias, forward bias, negative charge, etc.).
The panel below is made up of 36 Individual Solar Cells (36 Cell Panel), in this case it is 4 rows of 9 cells. Some of the older panels may be 32 (4 x8), there are also larger panels such as 60 cells (6 x 10) and 72 cells (6 X12). I will use the 36-cell panel for most of this discussion, but most of the data will apply to other panels.
The cells are connected to each other in series, each cell puts out about 0.668 volts, so when connected we gat 36 X 0.668 = 24.06 which is the Voc of the panel. Each cell also can provide 9.77 Amps which is Isc. A shaded cell will drop both voltage and current it produces dependent on the amount of shading. The impact of a shaded cell goes farther than just the shaded cell. The cells are attached in series, and the lower current output of the shaded cell will limit the output of the other cells connected in series. This is much like a blockage in a water pipe, will limit the flow of water in the whole pipe. So, if one cell is shaded and puts out only 2 amps than all the cells in series will put out only 2 amps.
The problem with this is that the power created from the other nonshaded cells, must go somewhere. Unfortunately, because some of those technical issues (reverse bias) we see the shaded cell now becoming a consumer of energy, which creates hot spots. So not only does shading rob our overall system of power output, it can cause hotspots that can affect the lifespan of our panels.
Luckily the panel manufacturers put in some protection to offset the problem of shading. These protections are really to prevent hotspots, rather than provide better output. As we said the single shaded cell restricts the current of all the other cells in series, that current must go somewhere and generally its get dissipated by the restricted cell causing hot spots. This is where the bypass diode comes into play, when a diode is placed in parallel with the offending cell (in the opposite direction) the diode will create a short circuit around the cell letting that backed up power to go by. This of course limits the hotspot but does remove that cell from the capabilities of the panel. This sounds great if every cell has a bypass diode, then why should we worry. Well, because the diodes cost money, and it becomes a tradeoff of protection to cost. There is a least one solar cell manufacturer that has a built-in bypass diode, most do not and typically we will find them installed in the junction box.
A very typical layout would be to have 2 bypass diodes for a 36-cell panel. That covers 18 cells with each diode. 60 cell panels usually have 3 bypass diodes across 20 cells.
Now what does all this have to do with the panels on our roof? Well first, we eliminate any shading in our layout. Many times, we have seen where the rack, vent or equipment box was shading a panel from the get go. Where you may run into some shading you can try to minimize it. In the following examples both have heavy shading of 4 Cells, but the resulting output of the panel would be completely different. In one case the shaded cells are across cells contained in both bypass diode circuits. It would essentially put out no power.
The second example shows the four shaded cells contained in one bypass diode circuit. This would allow at least half of the panel to produce power.
Now, before you go start rearranging your panels, let’s dive a little deeper. The first thing we need to look at is what kind of controller do you have? If you have a PWM controller you should stay in your seat. Imagine the above panel being an 18-volt panel, if we bypassed half the cells we could only expect half the voltage or 9 volts. This means the PWM controller would not have enough voltage to operate. If you have a MPPT controller, you could still pull some power out of this panel.
An example of tweaking the layout can be seen below, same two panels but with different panel orientation. In the top layout we can see some possible shading issues caused by the storage box. This is limited to some degree by the orientation of the panels. Shading by the box will only encroach on one of the two panels, and at worst one group of bypassed cells.
In the example below, the box now is encroaching even more, guaranteeing more shading. The real problem is now we shade across both panels.
The next layout is a classic problem, bars going over our panels. This example is somewhat exaggerated but its always good to check the shadow of bars, lights etc.
Another thing to consider is roof vents, please check the shadow when the vent is in the most common up position and make sure where it is casting its shadow.
In general, just use some common sense, most of our shading issues are going to come from other site issues. A disconnect switch may be useful, if you need to store items over the tops of your panels for various trips.
A couple of extra notes, as the solar cells seem to get more efficient year after year I expect that you will start seeing more bypass diodes, obviously the more current a cell can produce will impact the number of cells that can be protected by a single bypass diode. The number of diodes is not even listed on the spec sheets of most panels, you may have to call the manufacturer. My panels have three bypass diodes across 12 cells each instead of the 2x18 configuration
A couple of good YouTube videos to explain the technical aspects of shading can be found here:
hope this helps a little.
Amazingly helpful post
Thanks for taking the time to do it for those of us still studying to learn before we install
2001 Ford E150 HighTop Conversion
Based out of the Sacramento Valley
Northern California
OutlawImages is offline   Reply With Quote
Old 07-03-2019, 09:30 AM   #44
bigriver's Avatar
Thanks Greg! The willingness of this forum's members to take the time to share their knowledge is appreciated and inspiring.
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
Old 07-04-2019, 08:15 PM   #45
I agree, very good people in here willing to share
Much appreciated
Northern California
Old 02-21-2022, 12:23 PM   #46
FatLady's Avatar
Solar Installation and wiring support
HI team - I NEED HELP
I would need some support adding solar to my E350 Sportsmobil with pop roof. I was looking at 2 of the 115 W ZAMP panels with a 30 ah controller.
I have no electrical THUMb so to say and would love any input from you guys on what the best way would be to:
1. attach 2 panel to roof with potential allowing to stand them up and angle
2. were and how to run the cables to allow the pop roof to function and not to be in the way
3. were cables need to run to in order to maintain the batterie correctly and how to attache or involve the inverter ( I have a prosine inverter and a brand new AMGD4 deep cycle housebatterie under the car)
4. any advise in the LA - south bay area who could support me on that mission if I can't figure it out myslelf
any input welcome thanks team
Sue and the Fat Lady
FatLady is offline   Reply With Quote
Old 02-21-2022, 03:29 PM   #47
ctb
ctb's Avatar
Send a message via AIM to ctb
Hey Lady!! In a different thread, a member pointed out how most of the time we all look for some kind of shade (IF possible) to help keep our rigs as cool as possible, and subsequentially pointed out that this kills the solar, so he went with portable panels. NO stress/load on the roof, can position about any angle using a 12 pack to some rocks (lol), run the cord to the panels from the shaded truck...truly a 'duh' moment for me...yes, still use the rooftop panel, but went with the portable for most applications/locations.
Ps Greg, I felt like I attended a great online course about solar panels! How educating without going over average understanding etc...most awesome
'13 MDX 'BigBlackmobeebs'
'01 Lexus 430 LS 'Luxobeebs
'20 Tacoma TRD OR 'Tacobeebs'
Old 02-21-2022, 03:41 PM   #48
FatLady's Avatar
oh Ok - yes well that makes sense .. if parked in the shade that's no god of course … I ll have a think about that. when she is parked at home she has a lot of sun all day and the batterie could be maintained perfectly. How do you wire the portable panels to your Marine batterie so I can recharge ?
Old 02-22-2022, 05:44 PM   #49
ctb
ctb's Avatar
Hey LADY! (In my best Jerry Lewis...lol) Some kits come with battery clips...some even include (albeit an inexspensive unit) a control unit to display voltage/battery condition...there are some real experts and threads that have talked about this in detail...try the search button on top
Old 02-22-2022, 05:51 PM   #50
Orv
Mine came with clips but I cut them off and wired on a plug. I installed a matching socket on the van; since my panels have a built in charge controller this socket goes direct to the house battery. Make sure to fuse the positive wire on the socket side in case something gets shorted, since that socket will be +12V all the time. If you have a battery monitor you'll want to make sure you wire things on the correct side of the shunt so the charge current registers; my shunt is in the negative battery cable so I wired to the non-battery side of it.
Also note that panels sometimes come with cheap controllers that can only charge lead acid batteries. If you're using lithium batteries you may need to replace the controller or your charge current will be very low.
N8SRE
Zengi
Amy V
Otter
