To follow up on this thread, I think the result was actually related to / caused by a failed alternator.
After getting a new battery installed on the van I was keeping a close eye on the dash voltage indicator and things seemed normal for a few days, then one evening driving home I noticed the battery voltage was low. I had a spare alternator with me so I installed it the next day and that seems to have corrected the issue.
What's peculiar is that the alternator must have been intermittently acting up and failing for a while. Backstory on this was that september of '22 my dash battery light started coming on and off randomly, I checked the voltage when the engine was on and off and everything seemed normal for the alternator charging the battery (e.g. ~14.3V while charging ~12.5V while engine off). But the battery light would intermittently flicker on and off. I figured it was a loose wire or something on the dash display so I didn't put too much worry in it since the starter voltage was behaving.
Needless to say, after the new alternator install was finished, no battery light on the dash so I guess the thing just slow burned for another 13 months before kicking the can. I've had other car's alternators go out in the past and it was always on or off: they either worked fine or died, no in-between where they kind of worked but intermittently.
I do have an isolator switch that connects the starter and house battery when the engine is running so the house battery can be charged while driving as well and I'm wondering if that played a role in the intermittent behavior: for instance if the alternator crapped out for a several seconds or minutes the house battery was supplementing the starter so no voltage drop would really be observed on the dash.
There still may be accessories (stereo & alarm) that slow draw on the starter but I think the bulk of the issue was related to that alternator.
I'll update this thread if I need a 4th battery from autozone in the course of 3 years. Least they've been honoring the warranty.
'08 V10 6.8L Ford E350 Superduty extended
