Re: What is the latest on Solar Panels?
Another vote for the Kyocera Solar panels. 125 and the new 135s.
I think I have the old thin GTs and still going strong after 5 years.
The solar panel reduces the number of trips to re-fill the Honda 2000 Generator.. by end of day camped, if not re-charged, the Honda pretty much tops off my 8D AGM battery. Sometimes I don't even bother starting the 2000..
Someday I want to switch from a 12v inverter to a 24v based TrippLite inverter. Hook up 2 8D's in series making 24volts and change out the solar charger and change out the solar panels if I have too, not sure. Tons more amps hours.. But I'm still mulling over how the panels would charge all that battery..
I think it's debatable if you get one piece 200Watt or more watts versus two Panels at 125-135watts or more..
I always try to go redundant and get at least 2..in case one doesn't work..
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
