Old 07-16-2022, 05:00 PM   #1
Amy V's Avatar
What is this?
Hi there,
Curiosity got the best of me. I'm assuming most battery vents are passive. Never seen a lever attached to one before. How is it to be used? Not mentioned in owner's manual and SMB technician said he didn't know.
20220716_143522.jpg   20220716_143606.jpg   20220716_143620.jpg   20220716_143652.jpg
Amy V is offline   Reply With Quote
Old 07-16-2022, 05:02 PM   #2
Amy V's Avatar
Back of closet shot
Old 07-17-2022, 05:03 AM   #3
marret's Avatar
Me either. Looks more like a drain pipe rather than a vent. I assume you confirmed the vent and positively traced. What type of battery(ies)? Could be closed if not needed.
Your second post photo looks like a water line.
Chris
Old 07-17-2022, 06:12 AM   #4
Twoxentrix's Avatar
I have a vent (looks identical) mounted on the outside of my Van, and it serves as a water line vent & overflow for my sink.
Old 07-17-2022, 08:21 AM   #5
REF
REF's Avatar
Send a message via MSN to REF
That looks like it could be a diaphragm pump at the back of the closet with the handle on it, where does that line terminate at the back of the closet?
Could be that the van had a different toilet installed at one point and that was used as a pump or flush out?
Where does the “Y” go to that’s behind the toilet? Anything under the van at that junction-Water tank? Grey water tank? Waste tank?
Could it be a manual water draw fill?
Old 07-17-2022, 09:16 AM   #6
gahamby's Avatar
That last shot is a bilge pump.
'07 GMC 2500 6.0
Old 07-17-2022, 12:04 PM   #7
Same here but mine is not mounted so high up. It's mounted at the level of my sink drain. Doubt the OP's setup has anything to do with overflow at that level. The hand operated looking bilge pump makes me wonder if it moves vapors if it actually goes to that vent. Seems more orientated toward a black water tank or maybe a vent for a composting head???
Old 07-17-2022, 12:34 PM   #8
Twoxentrix's Avatar
Yep - That was a little dumb of me - I didn't even look at the location in the pic.
Old 07-17-2022, 12:43 PM   #9
That is definitely a hand operated diaphragm pump normally used to pump water
Old 07-18-2022, 12:28 AM   #10
Amy V's Avatar
Good questions. I got under the van and indeed it does terminate near my current black water tank, where it is capped and bolted. There is one long pipe to that point. The gross news is that when I went ahead and pulled the lever today, I can hear water. I guess I'll get my mechanic to open the cap and then---look out below. Click image for larger version
