Old 06-05-2008, 05:01 PM   #1
Home built 2007 Ford E150 van with Sportsmobile top
I have now completed construction of my homebuilt 2007 Ford E150 Econoline Van with Sportsmobile Top.
See "Yahoo Groups" / "sportsmobile_owners" group / "Files" / "Terry's 2007 Ford Construction" folder /
"Terry's Ford Narative" file for details of construction.
See "Yahoo Groups" / "sportsmobile_owners" Group / "Photos" / "Terry's 2007 Ford Construction Photos"
for, of course, construction photos.
terry is offline   Reply With Quote
Old 06-07-2008, 08:34 PM   #2
2007 Ford Econoline van RV conversion with Sportsmobile top
Photos of my 2007 Ford van
Old 06-09-2008, 08:29 AM   #3
Terry's 2007 Ford van construction description & photos
Terry's 2007 Ford E150 Econoline van with Sportsmobile top
I bought the 2007 Ford van new, in late 2007 with the following Factory Options
installed:
4.6 L V8
Trailer Tow Package
Power Door Locks
Power windows
Remote Key less entry
Cruise control
power mirrors
I selected the Ford van over Chevrolet because of the much cheaper cost of the
this Ford van.
I selected the Sportsmobile top over the GTRV top primarily because of build
scheduling. I went to Sportsmobile Texas instead of Sportsmobile Fresno
because, Sportsmobile Texas would install a garagable top on the van, and
Sportsmobile Fresno would not. After I negotiated a early date with
Sportsmobile Texas, it only took Sportsmobile Texas a day and a half to install
the top. Normally it takes a day, but, because I was getting a low profile
powered top, it took more time.
See “Yahoo Groups” / “Sportsmobile_owners” group / "Files" / "Terry's 2007 Ford Construction" folder / "Ford Van Parts List.PDF" file for A list of Parts that I purchased.
As is indicated in "Ford Van Parts List.PDF" file, I purchased several parts from Sportsmobile as follows:
door catches, hinges, battery rack, inlet power cord & connectors, Penthouse
bed, hoop steps, and, of course, garagable "powered" top.
Note - I did not install a propane system, nor a furnace, nor a cook top in
this van. I have found that I do not cook inside. I use a portable 1 burner
stove for heating water. I have, previously had propane furnaces; but, I have
never used them in the van. I do have a portable electric heater. Without
any propane appliances, I had no need for a propane system.
A list of tools that I used in converting the van is as follows: Circular saw,
table saw, saber saw, belt sander, in line sander, "Kreg" pocket hole jig,
electrical drill, screw driver bits, Forsner bits, various clamps, soldering
gun, 48" guide for cutting plywood, 4 metal saw horses, and 4' x 8' x 1/2"
press board used as a layout table.
I started work on the van, in earnest, in early February 2008, right after I
got home from Texas. I did do a little work before the trip. I finished the
conversion in late May 2008.
The first things that I did was remove the back and side door thrush holds in
the van.
I then removed the jack mounting hardware.
I made a pattern/template out of heavy paper for the plywood sub-floor and
the vinyl floor.
I then cut the 15/32" plywood flooring using the pattern/template.
I installed a 100 Amp circuit breaker under the hood wired to the chassis
battery.
I then brought the other end of the electrical
wire to inside the van at the gas fill area.
Sportsmobile installed Penthouse top, and temporarily connected power from
powered roof control switch to electrical wire at inside gas fill area. This
allows me to raise and lower the top during construction.
I then planned the wiring. See “Yahoo Groups” / “Sportsmobile_owners” group / "Files" / "Terry's 2007 Ford Construction" folder / "FORDWIR.PDF" file for the wiring schematic.
I then installed the step hoops.
I then installed the 15/32" plywood sub-floor.
I attached the
plywood to the van sheet metal floor using construction adhesive and
approximately 250 1" x #6 flathead sheet metal screws.
Cut Vinyl flooring.
Design interior layout. See “Yahoo Groups” / “Sportsmobile_owners” group / "Files" / "Terry's 2007 Ford Construction" folder / "FLORDING6.PDF"
Make patterns for side walls.
Cut out driver's and passenger's side 3/32" Oak plywood walls.
I painted all Oak paneling and plywood with Verathane Satin.
Install foam & fiberglass insulation.
Install all walls.
Make patterns for rear side & rear wall panels.
cut out, paint, & Install rear side & rear panels.
wire roof wiring for 110ACV, 12 DCV, from drivers side to passenger side.
wire rear light to passenger side.
Install vinyl flooring. I used double sided tape at front back door and side door.
Make pattern for bench seats.
I used the "Kreg" pocket hole jig and screws for fastening all bench seats,
cabinets, and doors.
In addition, I used
wood glue for all joints.
Build bench seats. I used 15/32" Oak plywood for sides.
Install bench seats.
Install outside 110ACV input.
Install converter.
Install battery separator on drivers side, under bench.
Design drivers-side rear, front, and middle cabinets.
See “Yahoo Groups” / “Sportsmobile_owners” group / "ACREF2.PDF" , "MIDCAB.PDF" , AND "POTTI3.PDF" for drawings of these cabinets.
I then made a template/pattern for cabinet sidewalls.
I then made the 15/32" Oak plywood cabinet sidewalls.
Make the three drivers side cabinets.
Install the three cabinets.
Make template, cut out & install passenger side mount for battery meter, 12dcv
receptacle, 110 ACV receptacle, & pump switch.
Install 110acv receptacle & 12 dcv receptacle in drivers side bench. Install
110acv receptacle in passenger side bench.
Wire drivers side AC inlet, 110acv receptacle, DCV receptacle, front light,
converter, battery separator.
Wire passenger side AC receptacle, DCV receptacle, light, trimetric meter,
water pump.
Make cabinet doors.
Another technique that I have used to
finish edges of the Oak plywood is to use a very thin veneer oak with glue on
one side.
This looks better than the 1/2" x 1/2" oak edging that I used on
this van.
install drivers side cabinet doors.
Install floor pedestal plate.
Mount battery rack.
Install 4D AGM battery.
Complete passenger side electrical.
Install "Danhard" Air Conditioning Condenser.
Install A/C Compressor.
Install A/C Accumulator.
Install A/C hoses.
Install A/C Evaporator.
Install A/C Controller.
Wire A/C switches, thermostat, controller, compressor, evaporator, condenser.
Charge A/C
Install A/C trim
Install refrigerator.
Build table & additional plywood to make up bed.
Design Passenger side cabinet. See "Yahoo Groups" / "sportsmobile_owners"
Group / "Files" / "Terry's 2007 Ford Construction" folder / "SINK1.PDF" file
Build Passenger side cabinet.
Install Formica on cabinet, table top, and additional plywood to make up bed.
Install water system.
See “Yahoo Groups” / “Sportsmobile_owners” group / "Files" / "Terry's 2007 Ford Construction" folder / "WATER.PDF" file for drawing
of plumbing connections to tanks.
Build door panels.
Install foam and fiberglass insulation in doors.
Install door panels
Install side door threshold.
Make and install curtains.
Old 06-09-2008, 02:34 PM   #4
mmocken's Avatar
Send a message via AIM to mmocken
Thanks for posting all your details.
What costs do you think you saved by DIY?
What weight do you estimate you DIY SMB is? I always felt that SMB has cabinets, flooring, insulation that adds too much weight.
what's next?
Thanks, Marty
Marty's 'BearsMobile'
1995 Dodge SMB EB-20 + modified for shower in back, PH Microlite Starcool. 130k miles young!
https://www.sportsmobileforum.com/alb...a37caeae3a.jpg
mmocken is offline   Reply With Quote
Old 06-09-2008, 04:40 PM   #5
My 2007 Ford van hone built RV conversion
I added $15,000 cost in parts and tools for converting my van. This includes sales tax. The 2007 Ford van cost $19,800. A new RB12 costs $17470. Penthouse bed is $398. Danhard A/C is $2335. Porta Potti is $125. Powered low profile Penthouse top is $6500. There would be a $900 credit for no propane nor stove. The total is $25,928 plus $1880 tax for the RV conversion. Total is $27808. It looks like I saved around $13,000.on the conversion. However, I do not have as much standard equipment as Sportsmobile.
I do not know how much the van weighs.
Old 06-10-2008, 08:13 AM   #6
mmocken's Avatar
Re: My 2007 Ford van hone built RV conversion
Thanks for the details.
One last Q: How many hours do you think it took?
Also, I would say you saved about $8000 buy using a 2007 van.
Congratulations on the build, it looks great...certainly takes a lot of passion and sweat.
Thanks, Marty
Old 06-10-2008, 03:23 PM   #7
Terry's 2007 Ford van RV conversion
I did most of my work in Feb, Mar, & Apr 2008. I did some in Jan & May.
In those 3 months, I averaged 6 days a week at 4 hours a day.
I probably have around 400 hours in all. I probably have 50 hours in design and 50 hours in shopping.
I took 10 days to drive to Texas for the top.
Old 06-12-2008, 09:17 AM   #8
deminimis's Avatar
Impressive build thread. Thanks for posting. Very nice work, by the way. I originally thought about a home brew Sportsmobile, but quickly decided I just don't have the time (marriage is strained enough with buggy mods, motorcycle trailer building and old VW resto project). A home brew SMB would have cost me more in divorce attorney fees, so it just didn't pencil out. Congrats again. You've got a nice well-built ride.
Old 06-12-2008, 09:39 AM   #9
bitburger's Avatar
Nice!
While I don't have the skills to do it (or the interest), I can certainly appreciate those that do.
Great writeup and pictorial flow.
-Mark
2008 SMB EB-52, Quadvan 4x4, 6.0 PSD SOLD
2017 Ford Transit T250 148WB mid-roof w/ Quadvan 4x4
bitburger is offline   Reply With Quote
Old 02-04-2009, 05:06 PM   #10
Re: Home built 2007 Ford E150 van with Sportsmobile top
I have decided to sell my homebuilt Ford van with Sportsmobile top.
Price $33000 Milage: <15000 miles
terryjones1@hotmail.com
Velocista
Rocketboy
Biggie
Berta
