Keep it. And many days you will be VERY happy you did.
You can duct the floor heater vents under the cabinets by creating a slightly raised cabinet lowest shelf with the heat coming out of the toe kick.
If you are removing the plastic trim below the windows you will need to keep part of it as it has the excellent ducting for the heat to reach the floor. At least keep the part that transitions from the blower down to the rear most floor vent for the heater. Then create a 1" tall space below the cabinet for the heat to reach the cabin.
Your AC duct up the D-pillar to the ceiling - incorporate that into a cabinet or leave the trim.
