Old 12-12-2015, 08:38 AM   #11
Since I haven't mentioned it above...superb execution!
Would a check valve on the water fill line fix the bumper filling issue?......
Old 02-07-2016, 12:21 PM   #12
SixCardCharlie's Avatar
Extremely clean install! Going to have to copy you.
2004 6.0 PSD
SixCardCharlie is offline   Reply With Quote
Old 02-07-2016, 10:57 PM   #13
Pschitt's Avatar
You might also consider adding some air filters to your compressors. It's gonna become really dusty/dirty down there when you drive on gravels...
Old 02-27-2016, 03:11 PM   #14
Gone Traveling
Very clean setup.. but I'm not too sure it should have went under the van in this manor.. Lucky for us.. the is a small crawl space under the cargo mat located in the cargo area. This makes for a perfect location for our on board air system or "other" storage options. keeping a low center of gravity is the key in our build.
LostInTransit is offline   Reply With Quote
Old 06-21-2017, 08:17 PM   #15
bemerritt's Avatar
6 years later, anything you have changed or wish you did differently?
I am looking to do this and possibly fit a water heater there instead of the air. Also was thinking of a sealing quick disconnect in my aluminess bumper to fill the tank with a hose.
bemerritt is offline   Reply With Quote
Old 06-22-2017, 06:11 PM   #16
MadScience's Avatar
Edit: I should point out that running water is a real game changer in van camping. If you don't have it, put it on your list now!
I said I was going to re-do my fill spout, but I have not touched it since I hacked it in place right before leaving on a trip. It's working find and looks acceptable, but I may need to re-visit this if/when I do a swing arm for a generator box.
I made an extension out of an old insulated plastic coffee mug. I did sand it so it's pure black plastic.
The water system has been trouble free since I installed it. The nylon tank seems to hold up fine to all the rocks I'm sure I've thrown at it.
Old 06-23-2017, 10:10 AM   #17
MadScience's Avatar
On my air setup, I originally used a single Viair 400C. That was painfully slow to fill up the tires. I then added a Wolo (860-C). The Wolo is both cheaper and moves way more air.
If I did it again I'd go with two Wolo's. I'd also mount them on the frame rails, instead of in the old generator box.
97 Eco
MTDave
Sporty Spice
Tapatio
