Originally Posted by upsidedown
RLC85:
Can you post up some pictures and details of your axle install? I’m considering the same year axle swap.
Did you fab your own brackets? What coil springs did you use?
Thanks
Yes, I made all of the brackets and I used aftermarket radius arms for a super duty with a 6” lift. That way the brackets are tucked up tighter to the frame. Springs are cc880s with a 2” lift puck under them
