@WVvan - I had to show your inspection kitteh picture to the same friend who was my second set of hands. We're both
ichc junkies.
So, apparently I got lucky and hit Home Depot at the right time. I was looking for plywood to build some panels for the rear doors and the 51 cent wood bin was overflowing with scraps... so I stocked up on some odds and ends (51 cents each, except for my sheet of plywood):
For all the complaining I've done about what things cost... I am really appreciative when I score like this. So, anyway, I just finished cutting up some panels this evening. It's pretty straightforward stuff: draw lines, measure, redraw lines, drill, cut, sand, etc.
I'm not really ready to panel the inside out just yet. I built my two rear panels early so I could install the rear speakers that arrived a few days ago. I was terribly frustrated trying to figure out what size hole to cut. I kept looking through the paperwork searching for some kind of cut-out template. Finally, I noticed the template was printed on the back of the box!
The mount points of the speakers aren't optimal for sound quality. I had two factors push me towards their current placement. The first was a lack of room inside the driver side rear door due to the license plate indention. The second is the expectation of the interior build out. I don't want to cover the speakers with cabinets (when I build them) so I kept the speakers far from the van walls, closer to the center of the van. For my floorplan, I intend to have an open hallway down the center of the van.
I made a few fun mistakes along the way. Twice I installed the speaker on the wrong side of the panel. I did this the very first time I was checking out placement. Then I did it again doing the final assembly. I felt a little silly for that. I also completely forgot to cut out a hole for the door handle so you can't open the door from the inside. My roomie jested about it being a feature of a kidnapper van. I'll probably cut the handle out on Sunday (my next work day). Oh yeah, and one of the speakers is currnetly installed upside down... not that it matters much, but... still, it's upside down... oops.
The grain of the wood is mismatched and the panels are covered in writing. This doesn't matter as I'm covering them with Vinyl in the final build out. I have the Vinyl and glue and kinda want to cover them *right now*... but, I figure the longer I wait for the Vinyl, the less likely I am to get something on it or damage it. I need to get started on insulation and flooring soon anyway.
The week had a lot of other challenges. It rained on me a lot. I also attempted a seat mod that did not turn out. Here's the basic idea:
The name of the van is "Polar Bear" and I really wanted some bears on the backs of the seats. I also have some tears in the vinyl I was attempting to cover up. I used 3M spray adhesive to attempt to stick the bears down. I left the edges clean cut. The glue did not bond particularly well and the bears are just a bit too white. I'm even thinking about doing them in a darker color than the seats. The vinyl I used here is from the batch I plan to use on the ceiling.
And just because it's neat, here's a pic I snapped with my phone this morning:
It makes me wanna wander up into the mountains for a few months...
