Old 06-30-2011, 05:55 AM   #21
cygvan's Avatar
Re: push out van windows
i found some rear window louvers...and apparently there are part numbers for both fixed and hinged rear windows.
willpak manufacturer page for van louvers...
http://www.willpak.com/products/rear-window-louvers/
at bottom of that page there is a link to a .pdf
http://0037a4b.netsolhost.com/wp-con...VanLouvers.pdf
truck n vans sells them here
http://www.trucknvans.com/Van-Louvers-s/1793.htm
as for the hinged windows themselves...i found this page. if you click on the drawings, they will bring you to other pages that show the various rear window assemblies and part numbers with descriptions. i can see that there are definitely parts for 2003 express. google came up with this result after a couple of pages so it was pretty buried. i dont recall the exact search terms i used but it was like my 6th or 7th combination lol.
http://parts.nalleygmc.com/products/.../15982180.html
hopefully i can piece something together to get hinged rear windows and maybe even put louvers on em. i like the louver look.
hope the info helps
Red Zeppelin - 2003 Chevy Express 2500 6.0L 2WD RB
cygvan is offline   Reply With Quote
Old 06-30-2011, 09:12 AM   #22
Silver350's Avatar
Originally Posted by Nely
My 97 has pop outs on both 60/40 doors. But if you leave the window unlatched where the door lock is, someone can come buy, unlock the door and enter. So i assume it was change for that reason
Sent from my SGH-T959 using Tapatalk
I don't think anyone at the factory is thinking that far ahead.
My '08 has a pop out on the 60/ door, right where the door lock is, but not in the 40/!
Old 07-05-2011, 07:59 AM   #23
Saabman,
I like your thinking. Will look at them later today in my e350 to see if I can get them
to open wider.
Bigduke6
Bigduke6 is offline   Reply With Quote
Old 07-05-2011, 08:08 AM   #24
vwteleman's Avatar
Originally Posted by jage
I have one with really bad tint that I'd like to use myself.
Jage, do you think the hardware could be retrofit to your existing window? On my '08, the mounting holes for the fixed windows are on the sides whereas the opening hardware is on the top & bottom, so you'd have to drill new holes. May be worth a shot though.
Brent
Old 07-06-2011, 03:43 AM   #25
Originally Posted by Bigduke6
Saabman,
to open wider.
Bigduke6
Yeah I was thinking about it but haven't got round to taking the latches appart...
+ 2001 Saab 9-5 Aero Hirsch
+ fixed house (Argh)
Old 07-06-2011, 07:02 AM   #26
Brent
Drill new holes and have old ones. The popouts are also on a frame, not sure how the regular windows go in. I'll take photos if I think about it.
Old 07-06-2011, 08:28 AM   #27
Oh dear, I see a project in my future... yarg.
Old 07-16-2011, 06:17 PM   #28
GreyDawg's Avatar
My 1995 E150 cargo van had the pop-out windows stock from Ford. Can't comment on the side doors as I had a slider.
A junkyard here has a conversion van ~1994 with a pair of intact pop-out rear windows. Assuming I can figure out how to get the rear door panels/trim off to reveal the naked door, what tools will I need to remove the windows, frames and latches?
Thanks!
GreyDawg
GreyDawg is offline   Reply With Quote
Old 07-16-2011, 06:43 PM   #29
Greydawg,
My 95 takes a Phillips for some of
the plastic trim and the bottom latch. The top hinges look like a 10mm.
Old 07-16-2011, 07:02 PM   #30
GreyDawg's Avatar
Greydawg,
Right, then: a collection of screwdrivers and my set of sockets. Sounds good as I want to minimize the number of tools I have to lug out to the back rows of the junk yard!
GreyDawg
Beni
hildems
PigPen
velo47
