Old 02-16-2021, 05:42 PM   #31
Twoxentrix's Avatar
If the old style of Sportsmobile propane doors are no longer available, you may consider looking at different styles of Marine Deck access doors - Just a thought.
https://www.amazon.com/SEAFLO-Marine...-goods&sr=1-12
Old 02-22-2021, 06:03 AM   #32
TomsBeast's Avatar
Progress made
I finished the mounts, and cut the opening through both walls of the body sheet metal to create an opening. I also trimmed out the opening for the access door. Measure, cut, grind, fit, weld, grind, rinse and repeat
Underbody view
Door opening metalwork complete
Old 01-24-2022, 06:28 PM   #33
TomsBeast's Avatar
Resurrecting this thread from the dead; after 8 months off doing other things (reviving a Bridgeport Mill, preparing a car for Bonneville speed trials, rebuilding a flatbed car trailer, and my day job keeping me very busy) I started back on replumbing both fuel tanks, and the 7 gallon Manchester propane tank addition. I stopped in May after faring in the welded area with short-strand Marglass, and addressing some of the surface rust under the van with a wire wheel, acid and chassis black paint. Ugh.
fast forward to this past weekend; I have the plumbing needed (do you ever really have all the fittings? no...) the propane tank in place for it's final time. I now have a donor body panel from which to make a folding door.
I have several different door designs rattling around in my head, I just need to pick one and move!
Old 01-25-2022, 10:53 AM   #34
[QUOTE=TomsBeast;306722]Resurrecting this thread from the dead; Quote]
Wow, that’s been a long time coming. It will be nice to finally get it done…..
Old 02-08-2022, 08:00 AM   #35
TomsBeast's Avatar
I decided on a hinged frame covered by a skin.
Below is the borrowed section from a wrecking yard donor van.
Progress on the door frame
Old 02-08-2022, 08:08 AM   #36
TomsBeast's Avatar
parking brake cable mod
The parking brake cable bracket was in the way, so I drilled a new hole closer to the frame, trimmed the bracket away to make room for the tank.
The tank is in for (I think) the last time
