Originally Posted by 1der
Posplayr's recommendation for the bed rug is a really good one. No need for "battens" or fillers in the grooves, still air is a fantastic insulator.
For clarity, never lay any aluminumized material directly onto the van metal floor. Any moisture that gets in there (and it will) creates an electrolysis that will eat through the floor paint and into the metal. Rust will then eat away at the exposed metal.
And regarding bolting/screwing the plywood floor to the metal floor - remember every fastener is a potential sound and thermal conduit. Additionally, the rigs flex and twist. A plywood floor that is bolted to the metal floor will be unable to flex. A cabinet that is fastened to both the walls and a hard fastened to the hard fastened floor will have to take all of the stress and flex which in time will cause the cabinets to squeak or loosen.
1der, thanks for sharing your experience and insight.
I had planned on only bolting down the 3/4" ply using the existing seat mounts. My XLT EB has provision for the standard rows of seating providing ample number of locations to hold down the floor. I would not plan on cranking down the bots as it would just warp the floor and compress the van rug and rigid foam underneath. So red Loctite on the bolt would secure the ply well enough needing only a firm (e.g. 10 ft-lbs) torque.
This would approximate your "floating floor" if using only 4-6 loosely bolted 3/4 Ply on top of the rubber mat and foam.
As far as screwing in cabinets, I would not screw all the way through the metal floor which is why i would prefer and recommend 3/4' ply (vs 1/2").
Another point I should reinforce about the radiant barrier, foam and other such non-metallic insulation do not reflect heat, it only slows heat transfer. So whether keeping the heat in or keeping it out, the radiant barrier refects a relatively high percentage of heat.
As 1der has mentioned you don't want to put a radiant barrier against a metal floor (or the wall) because of electrolysis. However, there is no benefit in the first place. The metal floor/wall will conduct heat right into the radiant barrier nullifying any potential reflective benefit.
With a double layer of insulative flooring, you can get two radiant barriers (separated by insulation) creating a multiplicative effect of stopping heat flow (e.g. double-layer heat transfer coefficients 0.2*0.2=0.04 vs 0.2 for a single layer).
https://www.ecofoil.com/pages/how-do...20a%20building.
