Small Update:
-Few small updates for Vandit before we headed out on a trip along the Oregon coast.
-Added in an AMI billet locking fuel door. Thanks to a fellow forum member for passing on a link for it. It seems like they are getting harder to find now! I did make a slight modification of pulling the bolts out and painting them black that way it blends in a little more with the van.
-Then I started the process of adding magnets for my windows covers. I pulled each shroud off, placed the window cover inside the shroud, and let the magnets locate themselves on the backside. After some slight adjusting, I was able to get them to fit very nicely. I then marked the location with a sharpie and glued them in place. After the glue dried I covered the entire backside of the window shroud with some ⅛” foam I found on
Amazon in hopes that it would help deaden some of the plastic sounds of the shroud. After using them for one full trip it seems like not only did the window covers work great so did the foam and stopping some of the creaking sounds we heard from the shrouds.
-Next thing I did was add a 4” cleanout port to my freshwater tank. Still need to find the best solution to getting rid of the plastic taste, but it’s much better now that I can get inside the tank to clean it as well as had any cleaning solutions.
Before (view of the tank without fill panel behind the seat)
After
-I was having problems with GPS location while using wireless Apple Carplay with the new head unit, so I decided to replace the GPS antenna and relocate it to the center of the dash. Since I had to take apart the entire dash to do this I also decided to add a few USB charging ports to the dash. The two on the far passenger side are directly plugged into the head unit for wired Apple Carplay/USB functions and the other two are just your standard
Blue Sea Fast Charge USB ports. They worked great on the trip and the antenna swap fixed the problems I was having.
-I took a chance on a random
Amazon find for a Bluetooth controller as I have missed being able to switch songs quickly like in my Tacoma. It connects to my phone Via Bluetooth and runs off batteries. So far it works great for Pause/play and next and previous songs but can't get the volume control to work while the phone is in Carplay mode. Overall I am super happy with it. It is installed with double-sided tape behind the wheel so everything looks factory and it stays out of the way until I want to use it.
-The last main thing I did before the trip was to pull some Trek-Paks material that I had in my truck bed drawers and did a test repurpose in the van drawers. I only had enough to do one of the rear drawers and my main galley drawers, but I am very pleased with the result and will be ordering more for the other drawers.
-We had a great trip along the coast, the van worked great and like I said the window shades worked perfectly. Van stayed nice and even for temperatures. They were easy to deploy and stow and blocked out all the light outside. Ace our dog is very pleased with our camping setup!
Now I just need to stop kicking the can and place my U-Joint order!
