Old 12-29-2017, 10:57 PM   #1
6.0 low power
The other day I pulled a pickup out of the muck. I had it in high range 4x4. The turbo spooled up like I've never heard and I jerked him out of the mud. I unlocked the hubs and headed out. I didn't really notice anything until I went to pass a truck the other day and it seemed to be lacking power. The boost gauge doesn't climb as it did as usual. Today I again tried to pass and it felt like low power once again. So I did a hammer test and besides the low boost, full throttle made my EGT's jump into the red . Now I'm thinking stuck turbo but could it be something like a blown hose still partially connected? I'm no mechanic. Plan to have it looked at next Tues.
EDIT- I plan to drive it, any reason not to on flat ground? Been on the road daily and with normal driving the EGT's stay in the green zone.
Thanks for any suggestions.
Old 12-29-2017, 11:29 PM   #2
BPR
I would definitely check the intercooler plumbing and boots. Do you hear a whistle when boosting?
BPR is offline   Reply With Quote
Old 12-29-2017, 11:41 PM   #3
Turbo could be sticking but my guess is a blown CAC boot or crack. Also, inspect the MAP sensor hose. Any codes?
2011 VW TDI Golf for hwy fun
Old 12-30-2017, 12:32 AM   #4
Nope, no codes. I never even looked at the boost when I pulled that guy out but it was more throttle than I've ever applied since adding the tune. Stupid not just using the winch or just shifting to low range
Old 12-30-2017, 09:48 AM   #5
Yup, my first thought was an air leak between the turbo and the engine. Check all your hoses and clamps, or make up something like this. All you need to do is apply compressed air on the intake side of the turbo.
https://otrperformance.com/products/...ressure-tester
Old 12-30-2017, 01:19 PM   #6
MSD
MSD's Avatar
If you're not blowing black smoke every time you get on the throttle then the leak (if it's an air leak) is after the turbo and not before... at least that is what happened to me. During a cold spell last year I blew my in take hose off before the turbo and it was if I was rolling coal. I figured out what was going on pretty quick do to the loud pop that happened and then low power. Opened the hood and did a hose inspection and found it in a couple of minutes. There are other things that can cause low power but I'd check hoses first.
2003 Land Rover Disco II
1997 E350 7.3l 2wd - Sold
Old 12-31-2017, 12:42 AM   #7
Thanks. I'll have them look at that. If I open the hood and look I'll just slam it shut. Crap I have a hard enough time seeing the belt. I have done a alternator swap and had a lot of that stuff off but I'll just pay to have it done this go around.
Old 01-02-2018, 12:01 PM   #8
Friggin cat failed . Wow almost as much as a turbo or more.
Old 01-02-2018, 03:13 PM   #9
Bellpilot's Avatar
Well at least the surgery will not be as invasive!
2010 E350 6.0 4x4 EB 50 SMB
Old 01-02-2018, 03:25 PM   #10
Does CA look for a CAT (or maybe just a large tube that looks like a CAT)?
ADVMOBL
Botchan
Coddiwomple
Rpence
