Old 11-28-2012, 10:10 PM   #1
Anyone have experience w/ aftermarket Differential Cover?
I tried searching but cannot find the specific info....looking for experiences, pros/cons to putting on a larger rear differential cover. The current one looks pretty rusted. It's on a 05 PSD w/ LSD.
Any suggestions to brand, etc.
Thanks,
jeepone007 is offline   Reply With Quote
Old 11-28-2012, 10:23 PM   #2
Tapatio's Avatar
Re: Anyone have experience w/ aftermarket Differential Cover
I replaced my stock diff cover with a Dynatrac mainly to provide more protection in case I hit a large rock or something.
http://www.dynatrac.com/products/jk/diff-covers.html
ARB also makes a nice hardened cover that has a drain plug built in.
http://store.arbusa.com/ARB-Differen...001-P3575.aspx
Callsign KK6GIY
Old 11-28-2012, 10:53 PM   #3
I went with Mag-Hytec.
It has cooling fins, and also a temp sender port which was my main reason for upgrading. It has a drain plug too.
http://www.mag-hytec.com/
Old 11-29-2012, 08:34 AM   #4
x2
Current: 2014 15 Passenger V8
Former: 2009 SMB 4x4 6.0
Old 11-29-2012, 10:09 PM   #5
My Dynatrac rear cover snagged a rock on the rubicon trail and started to leak. I looked at skid plates but figured the plates would cause more of a problem if hit and jammed into the U-Joint. So I tapered the lip so it won't snag again. Hopefully I won't have that problem again.
Old 11-29-2012, 10:54 PM   #6
Ok, gotta ask - Did you cross the Rubicon Trail in your van???
Old 11-30-2012, 03:38 PM   #7
No way but a Rubicon trail guide was trying to get me to do it I accidently ended up on it and took the easy part back to tahoe...lots of big rocks though. That section really doesn't count IMO. I wasn't even in four wheel drive but thought I was
Old 12-01-2012, 10:25 AM   #8
I was gonna say - there are a few spots that are nearly too tight to get the 4-door Jeeps through...
Old 12-01-2012, 12:43 PM   #9
The guide seemed to think I could do it if I took all the bypasses. Yeah right. We came in at Miller Lake and took the trail a few miles to the staging area. Even though that section is easy, it's full of fairly large boulders and I hit my read diff about 3 times. It didn't damage the Dynatrac cover but broke the seal and I found a small puddle of oil on my driveway the next day
Old 12-01-2012, 05:50 PM   #10
In case anyone is wondering: IMO, having crossed the Rubicon Trail many times, by using "the trick" with the Atlas Transfer Case and a lot of time stacking rocks, you MIGHT be able to get an SMB 4x4 across the trail. However, there are several spots that are tight for Jeeps with granite on either side with no by-pass. Which is to say that you better not be in love with your paint or sheet metal...
That being said, if anyone wants to try, I'm there! I would love to watch! I'll bring my Jeep and a camera.
"Hi-jack" complete.
