brake sound Death Star alarm hum
Got to finally use my Van after a 11 month hiatus. As usual it didn't go w/o some hiccups. Fired right up after sitting in storage in AZ, but was a little louder. Clipped catalytic converter. Right out of the bat to the shop. Thought about putting a band-aid on it, but just went with proper fix. We had some weird sounds in the brakes coming from the front when put in storage last Aug after Baja and was still there...So while in Co. had the pads replaced rotors resurfaced. Brakes had about 45k on them. Sounds still there. Sound is a high hmm like the alarm when the Death Star is getting attacked with a little squeal mixed in mostly at lower breaking speeds, but not all the time. Calipers?, Vacuum line? Doesn't seem like a wheel bearing or front diff. Rear diff was replaced in 2020. Pretty much the the whole entire conversion has been replaced since it was p/u @ UJ in 2017. Seeing if any the experts can point me in the right fix direction? Thanks as always!
