You're getting charged a lot of money to have work done that I think is a prerequisite to driving an SMB anywhere remote. Serp belt, fuel filter, etc. Looks like the guy is hunting to get you near $7k.
Have they pulled the valve covers to see if the o-rings are pissing oil? $300 should at least gotten one valve cover off. Did they do a buzz test on the injectors. If not a lot of what I'm saying is making sense, that's where I was 1.5 years ago. On these older 7.3's you'll need to be pretty familiar given the robbery and lack of familiarity people increasingly have around them.
Swapping your fuel filter is a 30 minute job for a drunken hack.
Serpentine belt is a 5 minute job to install or uninstall. You should be comfortable doing that on the side of an Alaskan highway.
Originally Posted by maxswasser
I do have the Hydra Tuner and a pyrometer. I work hard to keep EGTs under 1250.
So I'm burning more oil than diesel, and feeling pretty confident that injectors need to come out. Any good reason not go with stock motorcraft injectors @$330 each? Does that seem reasonable?
Up pipes are also leaking, so they're going to replace those as well. Wicked wheel upgrade while they have the turbo out? Anyone have experience with that?
Here's my quote from the shop. Does this look reasonable to everyone?
Thanks,
Max
