Old 07-29-2016, 07:09 PM   #1
Ficara2015's Avatar
Engine shutting down while driving
I own a 2014 e350 with the 5.4l and twice now it's turned off while driving, no warning at all. All the alert lights turned on, on the instrument panel and then every thing turned off instantly as if the battery died. No lights, radio, nothing at all. I stopped put it in park and had nothing. I pulled the negative off the battery, put it back on and everything powered up like nothing happened and the van starts right up. Has this happened to anyone else? Any ideas what it might be? Any help is greatly appreciated, I live a couple hours from the closest ford dealer.
Ficara2015 is offline   Reply With Quote
Old 07-30-2016, 12:42 PM   #2
Sometimes battery connection can look good a first glance. Best to go through the easy stuff first. Look closely at the terminal ends for any white of greenish tints. Check all the grounds on the engine or frame. Sometimes a ground looks good and just needs to be cleaned and tightened.
Old 07-31-2016, 12:20 PM   #3
Bbasso's Avatar
Using any BT devices for the OBD2?
Rob.
Current:
And had three other E350s...
Old 07-31-2016, 03:16 PM   #4
Ficara2015's Avatar
Im sorry what's the obd2? Scanner?
Old 07-31-2016, 03:17 PM   #5
Ficara2015's Avatar
Thanks Dave. They all look good
Old 07-31-2016, 05:58 PM   #6
Bbasso's Avatar
Google " OBD2 bluetooth dongle"
But I'm sure you would have known if you had...
Rob.
Current:
Old 08-01-2016, 07:35 AM   #7
RandallDee's Avatar
I have a 2006 with the 5.4 and this exact same issue was happening with my van. Turned out to be the battery connection.
2023 Transit AWD w/ Van Haus build.
73 BMW 2002 O=00=O
RandallDee is offline   Reply With Quote
Old 08-01-2016, 12:29 PM   #8
dhally's Avatar
Our 2009 died. Turned out to be loose wiring in the dash. Was warranted.
2009 E250 RB 5.4L "SilVan"
Old 08-01-2016, 10:23 PM   #9
I fear if it is due to worn out ignition. check for a bad fuel pump. Security features might get messed up
MichaelMPerez is offline   Reply With Quote
Old 08-12-2016, 07:10 AM   #10
FWIW, I'm working on the rear of my van and I removed and reinstalled the trailer hitch....in doing so, I had to loosen a ground wire to the frame next to the spare tire.
......while this ground was loose (not fully disconnected) the van wouldn't start....tightened it back up last night and van starts fine. I suspect it's the ground leg of the fuel pump.
Agnes
alta825
Overland Van
TPowell
