Originally Posted by Chinook
Let's trade links then:
https://www.ford-trucks.com/forums/1...ead-heads.html
The only blub I found in that article was found under Cylinder Head castings ID'd as 1C2E. I've always contended ejected spark plugs were due two things: faulty initial installation (factory) and/or the ridiculously low torque value of 7-13 ft/lbs Ford's WSM spec's called for. My friend the mobile fleet mechanic who's responsible for about 55 E-Series vehicles of years including nearly every one produced up through 2013 tells me the ejected plugs DO still exist albeit a much less frequent rate in the years after 2009.
Originally Posted by JoeH
Question is how high is that standard these days?
That is a great question and one we'd all like to know before sinking a lot of money into something that might be all hype and next to nothing in substance.
Re: Ford reman's----the earlier 2V engines along with all other Modular Motors could develop issues with the timing chain guides wearing prematurely causing its own set of problems. Ford does use their newer "better" design chain guides on engines they re-manufacture--I'm sure one reason is that's all they have available these days. This was a running change so quickly found its way into production, the repair parts functions and naturally the read-to-go reman'd engines Ford sold.
My point is any change or improvement when/if made tend to follow updated parts or corrections made after field reports tell Ford there is a problem or area of concern. I am slightly skeptical Jasper spec's significantly different parts than those already designed and put into production by Ford. That skepticism includes any part Jasper would use that's different from Ford is because they can have them produced cheaper and be at least as effective. That's not a bad thing but it is highly likely the reason.
As for the ARP studs in diesel engines---that's smart move on any diesel reman or head service.
