Old 09-13-2020, 02:15 PM   #1
Oily leak in the rear, what is this part?
I've got an oily leak in the rear.
Must have happened en route as its made a mess all the way back. It also got the new spare pretty good, and deep in the treads. Will the rubber be compromised?
And can anyone identify this leaking part for me please?
Thanks in advance.
TRAVRSS is offline   Reply With Quote
Old 09-13-2020, 06:33 PM   #2
marret's Avatar
I can’t really tell from the photo, but brake line? I would not think there is an issue with the tire.
Check your brake fluid level?
Chris
Old 09-13-2020, 06:42 PM   #3
REF
REF's Avatar
Send a message via MSN to REF
Well....could be a number of things, brake fluid for starters, but also, did you just recently have your rear diff serviced? Even if not, it looks like your rear diff breather tube could go to the area in question, so it could just be diff fluid overflow coming out from the breather tube.
If you didn’t just have it serviced, you might want to check the fluid level and the fluid condition, if it hasn’t been changed out in a while, it could be contaminated, overheating and spewing out.
Old 09-13-2020, 07:16 PM   #4
Originally Posted by TRAVRSS View Post
I've got an oily leak in the rear...
Must refrain from a really juvenile comment....
Old 09-13-2020, 07:44 PM   #5
Did you smell it? Could it be fuel residue? Once you leak enough fuel, it does leave an oily residue after the lighter VOCs evaporate. I ask because it looks like that's your Evap purge solenoid that's oil-soaked.
Old 09-13-2020, 08:19 PM   #6
ShuttlePilot's Avatar
Did you smell it?
I'm going to preemptively walk down to the directors office to be available to sign my disciplinary action.
- Eric
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
Old 09-13-2020, 08:42 PM   #7
I did smell it and it smelled more like oil than brake fluid. AND I did have the rear diff "serviced", but that was last year when I put the ARB locker in, which is why I checked with you folks first... I don't want to drive it without brakes or with a leaked diff. Perhaps I should get it towed for service?
Here are a couple of pics of a tube that had a drop of fluid coming out today. If this is from the diff, that would be it..
Old 09-13-2020, 08:57 PM   #8
Yup. That's definitely the diff breather.
It's not normal to vent oil though, unless you put your van on its side. Or if it was overfilled and is foaming from being churned by the carrier.
Old 09-13-2020, 09:18 PM   #9
"...is foaming from being churned by the carrier."
I'm not familiar with this phrase.
Van hasn't been on it's side, but has been sloshed around quit a bit this summer.
Should I contact the fella that installed the diff?
It's weird, I had thought it was runoff from the angle I had it parked. Morning dew... but once I moved it again I noticed the ring o oil this time, and had a lk
A little more lowbrow humor to keep everyone entertained
Old 09-13-2020, 09:23 PM   #10
Do you happen to know what gear oil was installed last? Mobil 1 full synthetic gear oil is notorious for foaming and puking out the vent of diffs and transfer cases. Amzoil is near no foaming with Schaffer’s and Red Line oils a close second.
-Eric
