Originally Posted by dhally
I finally got this rear sway bar installed and a test drive. It made a very positive improvement in cornering and cross wind performance, on the pavement. Mrs. dhally could even feel the improvement sitting in the passenger seat (less roll). Haven't tested it on rough roads yet to see if we feel more bumps.
I had to get the bolts to attach the links to the frame at the Ford dealer - $30 for 2 bolts, 2 nuts, plus tax. Ouch! But, they worked perfectly. The holes were already in the frame. The driver side was really tight to get a wrench on the nut, with the fuel tank and brake lines in the way.
The old bushings looked OK. I figure I can always replace them or upgrade to polyurethane later if they get sloppy.
The used sway bar is 1-1/8" diameter and came off a 1996 E350 cutaway chassis.
Attachment 43782
Looking to add a rear sway bar as well. Do you recall the source of the U-shaped brackets and the U-bolts that mount the bar to the axle? I see a few kits online, but the prices are kind of crazy for what it is.
Would an exhaust pipe clamp do the job?
