Originally Posted by JoeH
I used a D60 on my full float swap but that requires use of the same spacers to keep a similar wms-wms. If you can find a D70 it's a little beefier and you may not need spacers.
Your best bet is to start with salvage yards and do a rebuild. But if money is no object you could source a D60 from dynatrac or a sterling from Ujoint. The sterling has a different wheel bolt pattern but I'm not sure what a Quigly uses. https://www.ujointoffroad.com/produc...-axle-stage-3/
There's quite a few axle threads in this forum. Here's one with lots of info: https://www.sportsmobileforum.com/fo...ime-30954.html
Hey Joe,
Thanks for the info.
The rear axles on our vans are all stock Ford axles with 8x6.5, but maybe some SMB factories through on spacers for aesthetics or installed spacer adapters (8x170mm) if Quigley through on a F-series front end with 8x170mm.
Yeah, I went through most of the threads.
CarringB mentioned 99-01 e350 SRW as being the years to look for since they had disc brakes and were non RSC?
Or, seek out 99-07 SRW cutaway (rear tank)?
Which vehicles came with the D70?
Sounds like if I find a full floating axle from a 99-01 SRW E350 the only modification needed is to weld on bottom shock mounts?
