Originally Posted by JWA
I'd also add an external if one doesn't already exist.
I added both the Wix and Magnefine in front of the radiator. I think they are free-flowing enough to put in series. They are plumbed at the output of the OE transmission cooler so there are no hardline changes required. When I drained the transmission I blew thru the return line (back toward the transmission) to push that last bit of fluid into the trans pan. So I should have no more residual fluid and it is equivalent to removing the hardline return line.
- Derale 13090 Transmission Filter Kit
- WIX 51515XP XP Oil Filter
- Magnefine 3/8" Magnetic Inline Power Steering Filter
You can add a temperature sensor (will need to be drilled and tapped) to the filter housing or buy them that way.
I added the drain plug you have recommended and so will be maintaining a regular full fluid replacement schedule.
One thing to be aware of that I ran afoul of is that when you R&R a bumper, the screw-in mounts on the bumper are mounted in rubber so DO NOT OVER-TIGHTEN bumper mounting bolts. Otherwise, you only need to remove the bumper to do the install bout for any further filter changes. I did need to make a small bracket to mount to the driver-side radiator mounts.
The total miles on my 2000 E-350 XLT is 300K but the transmission looks rebuilt (very clean exterior). I don't know much of the history but the rear end was rebuilt (probably in place) and from what I read the transmissions don't typically last this long. After the idler pully changes the engine sounds great and ran well when I initially test-drove it.
When I swapped the fluid it was pretty black although not burnt. I got nervous after reading about horror stories about failed transmissions after a complete flush. The only problem I ran into (after the flush) was backing up the transmission would lock up and stall the V-10
I put in the Lucus and the problem was immediately gone.
