Old 11-18-2007, 04:58 PM   #1
Aftermarket penthouse lifters
Does anyone have information on how these things work?
1999 Ford E-350, Quigley 4wd conversion, 7.3 L Powerstroke Diesel
oldgoat is offline   Reply With Quote
Old 11-19-2007, 05:39 PM   #2
Does anyone use one of these units?
I'm thinking that a large thule box filled with gear and 3 surf boards will be nearly impossible to lift.
Anyone have a perspective?
Old 11-19-2007, 05:56 PM   #3
Where did you see them? What brand or company?
Old 11-19-2007, 06:14 PM   #4
Sportsmobile offers this aftermarket Penthouse lifter for around $500.
Old 11-24-2007, 11:38 PM   #5
I'm surprised that nobody has any awareness of this product offered by SMB.
Old 11-25-2007, 08:35 PM   #6
So you are referring to the electric penthouse top that Sportsmobile offers correct. I was thrown by term aftermarket in the thread. I have the electric penthouse top, and if you are expecting to put anything on your top over 75 lbs I think Sportsmobile recommends it. The electric option will get you up to 300 lbs (I think). My only concern is if it dies in the up position, and fully loaded., it is going to be a bear to get down, It looks like the actuators have quick release pins so you out to be able to pull the pins and hope you have enough people to let the thing down safely. Attached some pictures of the actuators, you can find them at http://www.techline.linak.com/Products/?id2=592
Old 11-25-2007, 08:40 PM   #7
Greg,
Thanks for posting those photos. Now I at least have some idea of how they are set up.
Old 11-25-2007, 08:43 PM   #8
Greg - Thanks for he reply. SMB does offer a Penthouse lift product for those of without the built in option. I haven't requested any info however will be this week.
Are the techline actuators available for after market installation?
Old 11-26-2007, 11:23 PM   #9
NRL
NRL's Avatar
Send a message via Yahoo to NRL
I was checking out the manuals.
Do you think it's the Model LA31 EL?
On the bottom of the manuals lists the voltage specs and most of them are 24Volts!
Wonder how they are converting it to 24Volts from Sportsmobile factory.
I also saw the LA36 has a manual hand crank behind a plastic cover using a Allen key..
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
NRL is offline   Reply With Quote
Old 11-27-2007, 07:57 AM   #10
You know if they aren't converting it that might explain why the electric PH goes so slow...
Big Mable
Fikeadelic
My Van
bfolens
