05-17-2023, 11:24 AM
E350 Stock Replacement Headliner
I have a 2005 E350 Quigley Chateau. The short front section of the headliner isn't in very good shape. A combination of a windshield that leaked and the desert sun beating the front edge of it.
Does anyone have a source for a stock replacement headliners? They are discontinued from Ford. I did some Google searching and didn't come up with anything.
05-17-2023, 12:19 PM
You may be better served locating an Automotive upholstery shop to address your problem - would certainly advise to review any customer "feedback" published before you commit.
05-17-2023, 01:18 PM
Agreed ^^^, or even simpler to just find a replacement from a salvage yard. It takes about 10 minutes to pull one. Pull down door gaskets, remove a-pillar trim, pop big plastic push-pin thingies from across the back (some will probably break), remove visors and visor-keepers and it will fall right down on you.
If your van is gray they are very common. Tan much less common.
05-17-2023, 04:38 PM
Luckily my interior is gray. Yeah, I'll prolly need to go to the pick a part.
05-17-2023, 04:39 PM
...and you can also re-do yours with new headliner material; the material and adhesive are both readily available.
If you find grey or tan boring, you could do fake leopard skin, alligator, ostrich......the sky's the limit.
https://www.yourautotrim.com/
https://www.yourautotrim.com/auheclvifa.html
05-17-2023, 10:39 PM
Heh... I continue to be amazed at what an amazing resource this forum is. Good on ya BW.
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
05-18-2023, 05:06 AM
Indeed 'tis for certain!
05-18-2023, 10:06 AM
Damit, my To-Do list just got longer
Steve
2019 Yeti SB130 Turq Race X01
05-19-2023, 07:19 PM
If you do re-upholstery yours, be SURE! to use hi temp contact cement, or you will have dangle's the first hot day.
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
05-20-2023, 02:41 AM
I found that out in Tuscon big time.
