Old 05-20-2023, 07:34 AM   #11
Yes.....if it's a spray can it should say headliner adhesive.....or from a gallon can use DAP Landau top adhesive.
Old 05-20-2023, 10:11 AM   #12
https://www.amazon.com/3M-38808-Head...a-571170832538
Old 05-20-2023, 09:16 PM   #13
A video to help a headliner install.
Old 06-01-2023, 01:53 PM   #14
This is probably the easiest section of any vehicle manufactured. It has only the A & B pillar moldings and is so short it can be removed by one person. The material is readily available even at hoby stores. A novice would have an easy go at it.
Old 06-01-2023, 02:22 PM   #15
Originally Posted by 86Scotty View Post
Agreed ^^^, or even simpler to just find a replacement from a salvage yard. It takes about 10 minutes to pull one. Pull down door gaskets, remove a-pillar trim, pop big plastic push-pin thingies from across the back (some will probably break), remove visors and visor-keepers and it will fall right down on you.
If your van is gray they are very common. Tan much less common.
Along the same general thread...I am working on taking my van apart to do some soundproofing and carpet replacement. Where is a good source for all the push-pin thingies? I have searched a couple salvage yards and most are broken. I don't even know what to google on some of them...
Anyone have success finding the pins for the roof as well as the ones with the little screws in them at the door thresholds? There has to be a supply of millions of those things somewhere...
thescottgivens is offline   Reply With Quote
Old 06-01-2023, 02:33 PM   #16
There is a wide selection on Amazon. You can find it cheaper probably on ebay but returns are much easier with amazon.
https://www.amazon.com/dp/B07BHCZF7P...T1zcF9kZXRhaWw
https://www.amazon.com/GOOACC-Retain..._dp&th=1&psc=1
Old 06-01-2023, 04:01 PM   #17
Awesome, thank you! I dont even know what to search for when looking for stuff like this. I appreciate the help!
Old 06-01-2023, 09:27 PM   #18
I bought a kit with a wide assortment of clips and retainers a few years ago and it still comes in handy. If you can't find an exact replacement you usually can find one that will work. It is currently unavailable but many others are.
maptester is offline   Reply With Quote
Old 06-02-2023, 06:10 AM   #19
This is so great! Thanks everyone for the help!
Old 06-03-2023, 09:01 PM   #20
rt66paul's Avatar
Most larger body shops have a large assortment of these. They might sell you a dozen or so.
rt66paul is offline   Reply With Quote
