Old 12-23-2015, 12:19 PM   #11
If you want to run the heater continuously you need to make sure you have 12 volts applied to pin 10 of the time. If you put a switch inline with the 12 volts you can then use it as a time also. I thought SMB had the extra switch installed so this could be operated either way.
Greg
LanduytG is offline   Reply With Quote
Old 12-23-2015, 02:29 PM   #12
Jeffrey's Avatar
My 2008 SMB has that little rocker switch which allows extended timer use, keeping the heater on a very low setting all night for really cold nights. I recommend blasting it at high setting for a few minutes before shutting down after such a long spell to prevent fouling at the next startup.
Old 12-24-2015, 07:04 AM   #13
If it's just a question of programing the timer this video explains it in simple steps. He's a bit choppy with the camera but you get the idea. My unit is on a 14 hour run before shutting down. Barry
lonepeak is offline   Reply With Quote
Old 12-24-2015, 10:14 AM   #14
Probably worth noting that there are several different control panels.
Serenity
Makalu1
At-At
Dirk/co
