Old 11-20-2021, 05:26 AM   #11
BrianW's Avatar
Agree about a pressure leak, but it sounds like water is leaking somewhere too. My money is on the tank drain valve not closing fully.
Old 11-20-2021, 06:34 AM   #12
I found the thing that keeps the pump running when faucet valves are closed was I forgot to turn the fill valve back off, and the pump just runs putting water back into the tank.
Another potential leak area is the actual water fill/regulator itself
Old 11-25-2021, 10:08 AM   #13
I have almost an identical issue, Water disappears if the system is pressurized. I did figure out that I did have a leak, but it was so slow that the water would often evaporate before it pooled under the van. I was able to trace down the leak to the city water valve.
dorothyt7 is offline   Reply With Quote
Old 12-22-2021, 04:50 PM   #14
Hi All, I ended up taking her to a shop. I had a bad pump, and a leaky valve. Thanks for all your words of wisdom. Much appreciated and ready to roll into the New Year. Merry Christmas!
Glippie is offline   Reply With Quote
Tags
faucet, fresh water, lines, pressure, tank
The Yeti
TexGX
Big Grey
allenl
