Old 06-14-2008, 10:29 PM   #11
Hey Zugg,
Not sure what you mean about the CO2 being adjusted. I asked them about running it at high altitudes causing problems and they said no. I had been in Tahoe for a couple weeks when i had the problems with the air bubbles in the fuel lines and I even asked about high altitude possibly causing my problems and the guy said no it should be fine.
My setup is I have the vent coming out between the front seats and pointing towards the rear of the van. During the day I have it so it blows straight along the floor and at night i flip the vent around so it blows up into the penthouse top, keeps things very comfortable and pretty evenly heated that way. I also use insulating curtains that wrap completely around the penthouse... I made them out of warm windows fabric, that helps a ton with keeping an even temperature in the van.
Jeff
jeff@work is offline   Reply With Quote
Old 06-15-2008, 08:01 PM   #12
zugg's Avatar
Hi Jeff,
Thanks for your reply.
The tech person from Webasto said that I shoud have the CO2 adjusted for elevations above 5,000'. That's all.
When I talk to them again, I will get more details and let you know.
Could you send me some info. about the warm windows fabric?
I assume this is better than SMB artic shades? Cheaper?
This sounds like a nice setup you have.
Zugg
Always do your best!
zugg is offline   Reply With Quote
Old 06-16-2008, 11:00 AM   #13
Hi Zugg,
I'm not familiar with the SMB artic shades so unfortunately I can't compare. This is what i'm using http://www.warmcompany.com/wwtech.html There might be better fabrics out there but this one does work pretty well for me, keeps the heat in in the winter and really helps block the heat from the sun in the summer.
I purchased mine from a joanns fabric store, they have 40-50% off coupons all the time and I just used one of those so the price wasn't too bad.
Jeff
Old 06-16-2008, 11:15 AM   #14
zugg's Avatar
Hi Jeff,
Thanks for the informaton and the link.
I will check them out.
Check out this link, but turn down the volume!
I hope my pop-top will be nicer!!
Zugg
Old 10-28-2008, 11:47 PM   #15
cellularSTEVE's Avatar
Originally Posted by zugg
Hi Jeff,
Zugg
hey Zugg,
did you find anything further out about this adjustment for high altitude? I know Jeff@work is having some problems at high altitude and he was asked to bring it in to a dealer for some change.
did you end up buying one?
steve
Old 11-06-2008, 06:39 PM   #16
Just wanted to bring this back to the top of the list. We are getting ready to have our interior installed this winter (just have a PH top now) and plan to use a gasoline heater. Any updates on whether you are all still happy with them and what model you have would be helpful.
Thanks,
Steve
Old 02-02-2012, 01:11 AM   #17
Bbasso's Avatar
Re: Gas powered furnace
I hate to bring this old thread back to the top, but I'm in the same boat as Zugg.
Can anyone enlighten me on the Espar or Webasto gas fueled air heaters?
thanks!!
Rob.
Current:
And had three other E350s...
Old 02-06-2012, 06:37 PM   #18
I might be wrong but think Mac has the webasto gas version...maybe PM Mac or use the search here if you don't get an answer on this thread.
Good luck
Old 02-06-2012, 06:55 PM   #19
vwteleman's Avatar
I have an Espar Airtronic gasoline heater. Will be two years old this summer and no problems. It kicks out a tonne of heat. And no clicking noise that I have detected.
Let me know if you have any specific questions.
Brent
Old 02-10-2012, 06:26 PM   #20
Bbasso's Avatar
How hard was it to get the fuel line setup with the gas version?
thanks.
As for "ton of heat" does it cycle on/off a bunch, how's the flow/fan, anything else I might want to know about would be greatly appreciated
Rob.
Current:
The Wayward Bus
danbr
Agnes
alta825
