Old 09-24-2022, 12:05 PM   #1
Leak at city water hookup
I've gone from a small drip to a large leak that appears to be coming from the city water hookup, I think from a crack in that white gasket-looking thing that fixes the inside to the outside parts. Is this easy to find locally or simple to order from Sportsmobile? Meantime, I guess I'll caulk the heck out of it and see it that helps until the cure.
Makalu1 is offline   Reply With Quote
Old 09-24-2022, 12:22 PM   #2
simplesez's Avatar
No need to go to Sportsmobile. You can get all those parts at Ace Hardware. Get silicone not caulk.
Old 09-24-2022, 12:44 PM   #3
Thanks for the quick reply, simplesez. Am I going to have to remove that outside piece with the black gasket, also? I'm hoping not to have to mess with that and disturb yet another gasket.
Old 09-24-2022, 01:25 PM   #4
simplesez's Avatar
Yes you will have to remove that also as it is cracked. You can get a Shurflo water inlet at Ace or a RV store.
Old 09-24-2022, 01:36 PM   #5
I replaced mine a few years ago, it was cracked at the threads. Ordered a new one on Amazon- https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Pretty easy replacement, you will want some butyl tape in betweeen the water inlet and the van (the gasket). I am in SLC and have some extra butyl tape if you don't want to order a roll.
2010 V10 EB45 4X4
new2tx is offline   Reply With Quote
Old 09-28-2022, 03:08 PM   #6
Sorry, got sidetracked for a few days... does that amazon chrome exterior piece come with the white plastic piece that it attaches to on the inside? I guess I'm asking if that's a separate piece I need to find as well since it has a crack.
Also, will Permatex Max Flex gasket maker work as well as tape or other gaskets? I have no experience with this, but that's why I'm here, I guess.
Thanks again, I see a trip to town...
Old 09-30-2022, 08:00 AM   #7
Yes, it came with everything you should need. I’m not sure about the Permatex, but it could probably work.
2010 V10 EB45 4X4
Old 09-30-2022, 10:21 AM   #8
Thank you new2tx and simplesez! I appreciate it.
