It appears as if most all of the bolt locations should be accessible without much trouble as long as you can find where to drill.
On my 2005, I drilled up from the bottom, through the subfloor with a small drill bit in order to locate the holes. I then drilled down through the resulting holes in the subfloor with an oversized drill bit, being careful to not damage the mounting holes.
Bob
2002 Itasca 35U Motorhome
