Originally Posted by Big_ern_101
I can get this for you tomorrow afternoon. Will be an "RB" but those dimensions are all the same. Do you need the measurement to the rearmost plane of the rear bench seat measured vertical, or do you need the measurement to rearmost point on the rear seat mount? Because of the angle of the rear seatback, these will be different measurements.
Note that if this van you are looking at started as a cargo van there is no guarantee that it has the mounts for the rear seats or seatbelts. If you have the VIN you can look up the original seating configuration.
Thank you so much for taking the time - I owe you a beer
. Yes, exactly, it would be the rearmost plane of the second-row bench seat. Below is an illustration (click to enlarge), but I think we're talking about the same thing. The measurement between “A” and “B”.
Regarding the seat mounting points, I was under the impression that the mounting hardpoints/braces are there in all E-series, but the holes may need the threads cut if it's a cargo van chassis. This particular van's VIN check returns an "INCOMPLETE VEHICLE" for the body type category - it is an "RV PREP" EB; and I assume was a cargo van chassis originally that was sent direct to SMB. Regarding the seat belt mounting points, I assumed they were there as well behind the wall paneling, but maybe I'm wrong.
Originally Posted by posplayr
Yea the back side some of those mounting points may not be readily accessible and you don't want to use Revnuts.
See above - as I understand it, the mounting hardpoints should be there on the body, but the holes may need to be tapped.
