Old 03-27-2024, 06:06 PM   #11
Originally Posted by posplayr View Post
It appears as if most all of the bolt locations should be accessible without much trouble as long as you can find where to drill.
On my 2005, I drilled up from the bottom, through the subfloor with a small drill bit in order to locate the holes. I then drilled down through the resulting holes in the subfloor with an oversized drill bit, being careful to not damage the mounting holes.
Bob
2002 Itasca 35U Motorhome
BCam is offline   Reply With Quote
Margot
FCAshevlle
Clyde
ormtnbiker
