Propane hose...
My 06 SMB RB50 came with a hose that I was told would allow outside connection of a camp stove to the van.
Doesn't seem like it, as I cannot find a single fitting that would allow it.
Soo..., when the van went on for its galley makeover, I had them add two additional propane outlets with qd fittings.
One inside the now floor mounted pantry cabinet, for a small one burner unit for morning coffee if the weather sucks.
The second one is just in front of the passenger rear wheel and is for my Camp Cheff Everest that sits on a tire table.
These are both connected just down stream of the propane line that feeds the furnace.
This all sounds fantastic until you realize that the new connections are post regulator and RV propane pressure is a whopping .05 psi and these camp stoves are designed to run on 15psi...
Has anyone successfully plumbed in a PRE regulator propane line for running camp stoves?
Thanks!
