Old 05-04-2021, 02:50 PM   #1
Silicone/Sealer recommendation for sealing wiring harness leak in roof
Need to remove old silicone Silicone/Sealer that is not keeping water out. Any recommendations on type of Silicone/Sealer for sealing wiring harness leak in fiberglass roof?
Magnus is offline   Reply With Quote
Old 05-04-2021, 07:59 PM   #2
Try Sikaflex - on Amazon - black color - pretty sticky, gooey stuff ! Use but don't overuse as it is messy !
Old 05-04-2021, 09:40 PM   #3
Many in the RV community use Dicor self-leveling lap sealant on around roof fans, AC units, solar wires etc… anywhere there is a potential leak or to repair an existing leak. It comes in white or black (and leveling or non self-leveling). Some say to use black only, even on a white van, as the white product gets dirty and yellows with age. I used it on my transit roof as a preventative measure to cover the the bolt hole roof caps that are on these vans.
Scott
2019 Transit 350 HR Eco Quigley 4X4
“Vandemic”
Charliesmom is offline   Reply With Quote
Old 05-05-2021, 08:45 AM   #4
gahamby's Avatar
3M 5200 is hard to beat but it is a permanent solution.
'07 GMC 2500 6.0
Old 05-05-2021, 10:07 AM   #5
another resource - https://www.sportsmobileforum.com/fo...ons-18369.html
this is what we've used on our van because we prefer zero-to-low VOC's:
https://chemlink.com/product/m-1-uni...esive-sealant/
and where to buy - https://store.concreteexchange.com/p...dc8a3757&_ss=r
we've used chemlink M-1 to mount l-track to the penthouse roof, to seal the weld mounts (t-nuts) before coating the penthouse with monstaliner, to attach awning brackets to the body, to attach weld mounts to the penthouse for mounting lights + camera, to seal body cracks, etc.
other options in the zero-to-low VOC realm:
https://www.greenbuildingsupply.com/...ants-Adhesives
Chris
2006 E350 EB 4x4 SMB: 6.0L-5R110-Atlas-D60-D60FF-yada-yada-yada
Old 05-13-2021, 03:45 AM   #6
Rather than look for a sealant perhaps a Blue Seas Cable Clam would work in your situation?
I used one running a reverse camera through my fiberglass raised roof, used just a dab of GE 5000 Silicone sealant too but honestly the Cable Clam seems to work without too much extra sealant etc.
HTH
Old 05-13-2021, 09:55 AM   #7
gahamby's Avatar
https://www.bluesea.com/products/cat...23/Cable_Clams
Those look pretty slick. I will keep them in mind.
'07 GMC 2500 6.0
Old 05-26-2021, 09:33 AM   #8
I recently used the Dicor 501LSW-1 to recaulk my RV roof, and I’m happy to see no drop inside the RV when we had a heavy downpour the next day. The consistency isn’t the same as water, but more of a runny putty. The roof sealant flows and spreads easily using a putty knife.
Andrew Coates is offline   Reply With Quote
Old 05-26-2021, 11:06 AM   #9
I used cable clams for the solar on my roof. That was four years ago and its never leaked a drop. I also used Dicor self leveling sealant on the roof vent.
Its good stuff and will stay in place far longer than silicone sealant imo.
ScrapIron is offline   Reply With Quote
Old 06-04-2021, 07:00 AM   #10
Cool devices those Cable Clams huh?
Tags
silicone/sealer
AWOL
Twoxentrix
Faultine
rizzabove
