Old 02-01-2021, 10:55 AM   #621
REDOVAL's Avatar
Well we made it through January so it’s time for another update on some of the products available through Vantage Optics and a new coupon code. Apply VOFEB2021 and save 10% on any purchase through the end of the month.
In addition to our headlight kits available for Ford and Chevy vans (links below) we now offer several other new products that may or may not catch your interest!
Ford Lighting Options-
https://www.vantageoptics.com/shop/F...Kits-c25728076
Chevy/GMC Lighting Options-
https://www.vantageoptics.com/shop/C...ghts-c25761007
Ford Econoline Underhood Service Light Kit-
https://www.vantageoptics.com/shop/V...Kit-p276199702
Ford Econoline vans from 1992-2007 (08-current kits in process) do not have any provisions for light in the engine compartment. If you've spent any time around vehicles you are aware that they never break or need work when it's most convenient! This kit aims to provide an easy to install light kit that provides plenty of usable output with a push button on/off switch. As an added bonus this kit allows for an optional remote light kit to provide light exactly where you need it on the vehicle.
Features-
-Application specific kit (universal also available soon)
-High output LED light with aluminum housing
-Push button on/off switch
-All wiring/connections provided
-Fused power lead for protection against over-current
-Minimal modification needed to install
-Single Weatherpack lead for system expansion
-Optional remote Profile magnetic work/camp light assy
Vantage Optics Remote Service/Camping Light Kit-
https://www.vantageoptics.com/shop/V...Kit-p283641007
Add bright usable light where you need it with this clever add-on kit. With its magnetic backed Profile LED light and long extension lead you will be able to place the light in the optimal location to make your repair or set up enough light for camping applications. Current consumption is very low and will last a long time on your current vehicle battery power before having issues.
Features-
-Profile magnetic light assembly (white light)
-12" fused battery lead (inlcluded but not shown at this time, compatible with other Weatherpack connector items)
-Weatherpack connectors provide a durable joint
-Optional cigarette lighter outlet harness allows use without battery connection (assuming the outlet is hot when the vehicle is off)
-Enough cable length to provide access anywhere on your vehicle
-Easy to store via the magnet or optional Molle style pouch
Vantage Optics Universal Dust Light Kit-
https://www.vantageoptics.com/shop/V...Kit-p276476366
Offroad rigs and vehicles and traveling in low visibility conditions (snow/fog) can benefit from a rear facing amber light assembly (same concept as fog lights). The amber-colored light cuts through dust and inclement weather to make your vehicle seen and noticed before accidents happen. This unique kit aims to provide universal use in most any vehicle that has a standard cigarette lighter port available. The light is intended to be mounted to the inside of the vehicle's rear window using the Ram Mounts®️ Twist-Lock suction cup mount. Providing the window is properly cleaned prior to mounting the light assembly it will stay put even in very rough conditions.
Light Options-
-Baja Designs®️ S1- amber light features a wide cornering lens (2375 lumens)
-Diode Dynamics SSC2- Pro and Sport models with an amber combo lens (777 lumens Sport, 1858 lumens Pro - measured)
-Whelen Ion (possible in the near future)
Features-
-Steel-it®️ coated steel bracket (two configurations available based on window slope)
-Ram Mounts®️ Twist-Lock suction cup mount
-Weatherpack or Deutsch Connectors depending on the light
Benefits-
-Universal use on any vehicle with a rear window
-Non-permanent installation
-Secure theft-proof mounting inside the vehicle
-Super bright Baja Designs or Diode Dynamics light
-25' length fits even the longest vehicles
-Low current draw (~1.7A)
-Includes an adapter for use as a cigarette outlet extension
-Make any vehicle a chase rig for offroad racing
Options-
-Optional Profile magnetic service light assembly uses the same wiring for remote use
-Optional sealed and padded carrying case protects your investment when not in use
Availability-
These kits are made per order at this time and take about 1-2 weeks to process as we ramp up production. Thanks for your patience!
VO 3156 LED Reverse Light Bulbs-
https://www.vantageoptics.com/shop/V...lbs-p131966176
Replace your incandescent 3156 bulbs with these bright white LED replacements. They simply pop in and work great to add more light wherever you need them. We use them as reverse bulbs and find them to be a great improvement over the OEM units. These work well in both OEM and aftermarket taillight housings
VO Big 3 Cable Kit- 97-14 Ford Econoline Gas Engines-
https://www.vantageoptics.com/shop/V...nes-p219068555
Optimize your 97-14 Ford Econoline gas engine charging system with this kit. Modifications to the OEM battery terminals are required to install the kit, but they can be done with simple hand tools.
This kit allows for enhanced alternator to battery connection and engine block to both chassis and battery ground connections using oversized USA made 2/0 Excelene welding cable. Most electrical system components in the van platform are woefully undersized preventing proper alternator efficiency and premature battery failure. The addition of the military terminals allows connection to the battery for additional components in a very efficient and aesthetic way to reduce wiring clutter.
Fitment-
97-14 Econolines with the 4.6/5.4/6.8 Triton engines
Kit contents-
1x 2/0 Alternator to battery cable (USA made components)
1x 2/0 Engine block to battery cable (USA made components)
1x 2/0 Engine block to chassis cable (USA made components)
2x military style battery terminals
1x clamp
2x bolts to secure ground locations
Disclaimer- Installing this kit on your vehicle will provide a direct connection from the alternator to the battery. Any and all ill effects arising from the improper installation of this kit lie solely on the buyer and installer.
Scott Thompson
Vantage Optics
vantageoptics.com
Vantageoptics@gmail.com
20180730_180041.jpg   20201213_082723.jpg   20201230_171804.jpg   20200718_130836.jpg   20210106_155306.jpg
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
Old 02-01-2021, 01:53 PM   #622
bigriver's Avatar
Great to see your high quality product line expand with these useful additions. Good work.
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
Old 02-01-2021, 03:26 PM   #623
REDOVAL's Avatar
Scott Thompson
Vantage Optics
vantageoptics.com
Old 03-04-2021, 10:51 AM   #624
REDOVAL's Avatar
Another month in the books and as we start into March we hope you all are healthy and getting your rigs ready for Spring and Summer adventures! To help you prepare our SMB discount coupon code now includes FREE SHIPPING in addition to the 10% off! Use code VOMAR2021 and be sure to check out the site for updates and new products.
Also keep in mind we are now offering Chevy/GMC 03-current retrofit headlights as well that perform and look amazing!
Scott Thompson
Vantage Optics
vantageoptics.com
Old 05-03-2021, 11:24 AM   #625
Hi @redoval anychance you're doing a discount code for May?
WhiteWashSurfer is offline   Reply With Quote
Old 05-03-2021, 11:33 AM   #626
REDOVAL's Avatar
Absolutely! Use code VOMAY2021 to apply a 10% discount on all products we offer! Thanks for the reminder!
Scott Thompson
Vantage Optics
vantageoptics.com
Old 05-05-2021, 02:33 PM   #627
Much appreciated. Placed my order on Monday.
Old 06-07-2021, 11:42 AM   #628
REDOVAL's Avatar
Well here we are now in June and we have a new code for our SMB family. Use "SMBSUMMER21" and get your rig ready for a summer full of adventure!
Be sure to check out our latest products on the site as well.
https://www.vantageoptics.com/shop/V...unt-p356526255
We also have steering damper kits and A-Pillar mounts in stock and ready to go!
https://www.vantageoptics.com/shop/9...-Kit-p85434830
https://www.vantageoptics.com/shop/V...kets-p73168518
Scott Thompson
Vantage Optics
vantageoptics.com
Old 07-01-2021, 01:47 PM   #629
REDOVAL's Avatar
July is here and it's time to celebrate this great country's birthday! We have a dedicated July 4 Sale category and discount code good for 17.76% off anything in the category! Use code VO1776 to apply the discount.
Please be patient with the lead times for orders placed during this sale as we expect volumes to be very high and we will be in and out on vacation. Thanks in advance!
https://www.vantageoptics.com/shop/J...ems-c113744755
Scott Thompson
Vantage Optics
vantageoptics.com
Old 08-02-2021, 10:35 AM   #630
Youngster's Avatar
Hi Scott. I sent you an inquiry last week to your Vantage gmail, as a reply to my original order (Order 364).
One of my new Vantage headlights stopped working after a year. I need to know how to trouble shoot and what parts will be needed. Can you check your emails and get back to me?
Thank you!
-David
2016 Beta 500 RS
2014 KTM 350 EXC-F
Youngster is offline   Reply With Quote
