10-07-2022, 02:43 PM
#671
Our October coupon code will be VOSPOOKYSMB and will be good for 10% off all products.
Keep an eye out for new products we are releasing constantly including the Max AC Kit and new power distribution panels.
Scott Thompson
Vantage Optics
vantageoptics.com
Vantageoptics@gmail.com
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
11-04-2022, 02:07 PM
#672
The new November coupon code is now active for 10% off using NovemberVOSMB. We expect a large wave of builds coming so get your order in to keep the wait times down!
Scott Thompson
Vantage Optics
vantageoptics.com
11-07-2022, 05:07 PM
#673
After dragging my feet FOREVER..I finally ordered a set of these, thanks for the discount code Scott! Looking forward to being able to SEE at night!
11-08-2022, 08:14 AM
#674
Awesome, excited to get your kit built. Thanks!
Scott Thompson
Vantage Optics
vantageoptics.com
11-08-2022, 10:24 AM
#675
Scott....if you were building lights for a '08+ Eseries and your goal was the best of the best components, what would those be?
11-08-2022, 01:34 PM
#676
MG-
Personally I'd go with the LED kit as it uses the very potent Morimoto MLED 2.0 projectors. The output is phenomenal and the installation complexity is reduced to a simple plug and play procedure. For the shrouds I like the look of the Apollo 3 (default selection) but since they set the "attitude" and overall look of the light without impacting output performance they aren't critical and come down to personal opinion.
The link below shows the installation procedure:
https://youtu.be/kqU63uRYmdQ
Product link:
https://www.vantageoptics.com/shop/2...ghts-p97762057
Scott Thompson
Vantage Optics
vantageoptics.com
11-08-2022, 04:19 PM
#677
VO Econoline Max AC Kit
Hi Scott.
I have a question about your product VO Econoline Max AC Kit
What does it do? Does it solve the 'hot dash vents' that blow hot even on cold days? Like mentioned here?
Thanks!
2016 Beta 500 RS
2014 KTM 350 EXC-F
11-08-2022, 05:29 PM
#678
Scott, can I use the LED's with the original projector's you supplied me with the HID upgrade? Thanks..........
11-09-2022, 08:00 AM
#679
Originally Posted by Youngster
Youngster,
The Max AC kit is a simple add-on cut off valve that is present on all other vehicles to maximize AC efficiency. For unknown reasons (likely cost) Ford omitted this feature from the Econoline platform. The intent is to stop hot coolant flow to the heater core therefore preventing the core from heating the incoming cooled air. As the systems age and seals deteriorate this becomes more and more noticeable.
Scott Thompson
Vantage Optics
vantageoptics.com
11-09-2022, 08:06 AM
#680
Arctic,
The HID kits use the H1 or D2S based bulbs and don't work well with LED bulbs as their construction and focal point length doesn't allow for proper output. The LED kit mentioned above is a dedicated projector based on an LED chip as the primary output component.
Scott Thompson
Vantage Optics
vantageoptics.com
