Old 11-23-2020, 08:58 AM   #1
F250 7.3 Diesel Questions
Hey y'all,
I am looking for the nitty gritty details related to the maintenance required to keep the 7.3 liter diesel engine running well. In particular, I am looking at purchasing a 2002 F250 with the Powerstroke 7.3 Diesel engine.
Thanks
Noah
NoahKroencke is offline   Reply With Quote
Old 11-23-2020, 09:10 AM   #2
Hey Noah check out deadheaddiesel.com and ford-trucks.com for more general questions about the 7.3 Powerstroke.
1998 E350 7.3 Hightop
r27d is offline   Reply With Quote
Old 11-23-2020, 09:44 AM   #3
REF
REF's Avatar
Send a message via MSN to REF
Welcome.....There’s no real routine maintenance items on the 7.3 other than oil changes. That being said, you’ll probably want to find a good diesel mechanic to plug in and read any codes present and maybe do a buzz test on the injectors and see if there’s any issues and check sensors. Go through and at least check if not change all fluids to get a baseline if you haven’t-oil, brake, diffs, trans, coolant.
Other common wear parts that begin to fail are the HPOP(high pressure oil pump).
Check the exhaust up pipes for any signs of leaking, another common point of failure and will cause low boost or poor performance, you’ll notice black streaks on areas around the flange, lots of diesel performance sites offer far superior bellowed up pipes, Dorman makes a decent economy copy.
Make sure the batteries are fresh and ground cables are clean and secured.
There’s really only a few viable upgrade options out there for the vans with the 7.3 that are worthwhile. There’s no performance intake available, but you can do a 4” exhaust. And hands down the best performance chip available for the 7.3 is the Hydra from Power Hungry Performance, wouldn’t recommend going with anything over their 60hp tune, not needed and the 40 and/or 60 will be everything you’ll need to really wake it up!
Get a scanguage or at least an EGT temp probe to keep an eye on exhaust temps.
Whatever you do, DON’T put in a DP tuner....complete garbage!
Old 11-23-2020, 09:58 AM   #4
Are you asking for 7.3L in an F250 (pick up truck) or an E250 (van)? There's no intercooler on the van version, and many more options and upgrades available in the pickup truck version.
Old 11-23-2020, 10:14 AM   #5
REF
REF's Avatar
Oh...good catch there
Old 11-23-2020, 07:43 PM   #6
Pretty sure the 7.3 only came in E350 vans, no? Never the 250...
2003 Astro AWD
2005 Tacoma Access cab 4x4
